"Saving As..." a blend file with a Script node file path filled with 1023 symbols crashes Blender. #81421
5 Participants
Reference: blender/blender#81421
Graphics card: NA
Broken: version: 2.79b through current master 2.91
4bf6ffc022
Trying to "Save As..." a new .blend file with a Script node set to external and the path filled with 1023 symbols will crash Blender and leave a 0KB .blend@ file.
I was trying to find a way to store a JSON inside a node group. I will try adding a custom property. https://docs.blender.org/manual/en/2.90/files/data_blocks.html#files-data-blocks-custom-properties
1. Open a new file.
2. Create a material and a script node.
3. Set the script node to external and fill the path with the max length string (1024 symbols).
4."Save As..." or "Save Copy..." the blend file.
NOTE:Steps 2 & 3can be done by opening the scripting workspace and running the following python code:
nodes.remove(node)
{F8951939}
Added subscriber: @unwave
Added subscriber: @StephenSwaney
Random guessing and no research says you are running up against maximum path length on your platform.
Added subscriber: @EAW
Windows has a max file path length of 260. In order to exceed this you have to enable
long paths
.https://docs.microsoft.com/en-us/windows/win32/fileio/maximum-file-path-limitation
If you want to store text, use the text editor under the scripting workspace.
https://docs.blender.org/manual/en/2.90/editors/text_editor.html
Closing this as it appears to be an issue with the default path length on Windows and not an issue with Blender. If this is not the case, let us know and this can be reopened.
It has nothing to do with long paths. I even have them enabled. Did you follow "Exact steps for others to reproduce the error"? I think it is because Blender adds
and crashes because of the 1023 chars limit. If I remove 5 symbols, it doesn't crash.201004_142842_%pn_%t.mp4
nodes.remove(node)
Changed status from 'Archived' to: 'Confirmed'
@unwave I missed the notification of your Oct 12th reply, sorry about that. Thanks for the PM to remind me.
Thanks to your script, I have a better understanding of the issue and I have been able to reproduce.
I agree. In my test 17 symbols were added due to the location at which I tried to save the file.
Blender crashes at:
This issue was referenced by
8926b09fa9
01d3fbc496
501854e4ee
