Blender has froze my Manajro Linux, which has corrupted my root Btrfs filesystem, rendering the machine unable to boot #81547
Reference: blender/blender#81547
Operating system: Manjaro Linux
Graphics card: Radeon RX 5500/5500M / Pro 5500M
Broken: Blender 2.90.0, 2.90.1, 2.91.0 Alpha
Worked: none yet
When doing a very specific thing in Shader editor using Eevee rendered, my system froze. I've rebooted and tried again. It froze again, only this time when I rebooted it I was greeted by an emergency shell. My root Btrfs filesystem is unmountable. I'm currently performing disk imaging, and will attempt to fix the FS or restore the system from backup.
Here's the screen that I saw after rebooting my laptop after the second lock-up:
I have a specific .blend file that when loaded on Manjaro Linux will freeze the system. I've tried again booting a fresh Manjaro 20.1.1. However it's a confidential client project and I cannot share it publicly.
I wasn't able to reproduce the problem on Windows 10 running on the same laptop.
I suspect the problem could be in an AMD GPU driver - it's the only thing that I believe has enough system access to mess up a roo t filesystem that was involved. And it's clear the problem was triggered by a certain material in Blender, while rendering with Eevee.
Note that the system won't freeze until I turn on Rendered view. Using Material Preview is fine.
Two first time when it happened it was immediately after I have added a mix node to add another texture to an existing image path in an Eevee material.
I thought that maybe texture sizes could be the problem, as I've been using 3 8K textures, and maybe the laptop's GPU can't handle that, but filesystem corruption should never be the result of that.
Added subscriber: @TobiaszunfaKaron
Added subscriber: @lichtwerk
Hi there!
Thats bad to hear.
Do you recall which driver version you were using?
Well, maybe you could still try to share just that Material isolated? Replace with same size (but sharable) textures?
P.S.: been following some of your Ardour stuff, thx for this!
I'm trying to prepare a minimal reproduction project, it didn't freeze the system yet, but exactly when I enabled Material Preview dmesg said this:
Changed status from 'Needs User Info' to: 'Needs Developer To Reproduce'
Added subscribers: @fclem, @Jeroen-Bakker
I am probably the wrong person to ask, @fclem / @Jeroen-Bakker : does this ring a bell?
I've loaded the full project and proceeded to freeze the system using a clean Manjaro Linux KDE 20.1.1 using SSH on my phone to log flesh. I got some juicy stuff here:
I've pulled the USB drive out to see if the kernel will note and then powered off the machine.
Here's the text version of this dmesg log:
dmesg.txt
I thought I couldnt reproduce this in Blender 2.90.1, but no - it's still there.
Only it took about 30 seconds for the freeze to happen this time.
Here is complete log from the whole SSH session, containing dmesg output since boot until freeze:
dmesg2.txt
Are you using the proprietary driver or Mesa implementation?
In any case, could you test with the other one? This would make us certain it's a gpu driver issue.
I had a hard time reproducing this in Blender 2.91.0 Alpha, but it happened.
It wasn't as bad though, as my laptop's built-in display didn't go black, and my mouse was still responsive (even though X>org has frozen).
I was able to switch o a TTY and log into shell there.
I've used Ctrl+Alt+Backspace shortcut to kill the X.org session and I was able to recover without rebooting, which is better.
Now - a small hint I have is that the problem only has occured once I have set SSS samples to 12. I was playing with various rendering settings for like 15 minutes to try and trigger the problem, and it only happened when I've risen SSS samples to 12 - I do have materials using Eevee SSS in the scene and they were rendered when I changed this.
Here's a complete dmesg output form my remote SSH session:
dmesg3.txt
Also, here's my hardware information:
Hmm. I was able to fully freeze my system again in 2.91.0 Alpha :(
I've tried reproducing this again and I was only able to do this when Viewport Denoising was on AND the SSS samples were high this time.
Here's extended dmesg output, it contains the dmesg3 file and more stuff that was printed after the last reproduction:
dmesg4.txt
You can also start using
--debug-gpu-force-workarounds
to see if that makes any difference.This is what I think must have happened:
I've sent a message to AMD tech support, hopefully they'll pick this up.
Bugs in the AMD driver are outside of our scope, also quite some time has passed. Therefore I am closing this one.
