Solidify "Thickness" value snaps when scene Units set to "Imperial" at Scale of thousandths (0.001) or less #81552
Reference: blender/blender#81552
Graphics card: GeForce GTX 1080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 432.00
Broken: version: 2.91.0 Alpha, branch: master, commit date: 2020-09-30 18:50, hash:
2c317457cb
Seems to be an issue even before the 2.8x+ series.
For some reason, the default Blender units seem to be 1000 times smaller than what it should be, leading to tiny models when exporting .stl files for 3D printing and opening in other programs (e.g. Cura).
So to compensate, I set the "Scene Scale" to 0.001.
An issue arises when I'm working in the "Imperial" Unity System and I try to change the Solidify Thickness value on an object.
Instead of smoothly changing values, it snaps between only two values (e.g. -0.393701" and 0.393701")
This issue goes away when simply changing the Unit System to "Metric", but this isn't ideal because I tend to work with measurements in inches for my models.
Test file: ImperialScaleIssue.blend
Added subscriber: @0o00o0oo
Added subscribers: @HDMaster84, @mano-wii
Thanks for the report, I can confirm the bug.
@HDMaster84, Is this something for you?
This is not specific to solidify. It also occurs with other sliders that are using the length unit like the merge threshold in mirror modifier and in weld modifier.
It occurs in imperial when the unit scale is smaller than 0.001.
For metric it happens with a scale of 0.00001.
Note: the weird stepsizes occur exactly when there is a length smaller than 1 thou/µm. Lengths smaller than 1 thou/µm are strangely enough displayed in the base unit (feet/m by default).
Also Note: for metric it is even weirder because at a scale of 0.00001 it shows actual wrong values.
The issue is somewhere in the execution of
ui_get_but_step_unit
ininterface.c
but probably deeper in the unit system.Changed status from 'Confirmed' to: 'Needs Triage'
So this is a problem with all sliders that use the unit system?
In this case, the report must be edited and directed to the #user_interface team.
new bug report with this issue with the correct project: #81664.
related #81663.
Thanks for the reports @HDMaster84 :)
I will merge this one into the #81664 then.
Closed as duplicate of #81664
