Add-ON: 3D Print #81716
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
5 Participants
Reference: blender/blender-addons#81716
I get an error when I click the "bounds" preference under "transform". Im using a MAC with Catalina latest version.
Added subscriber: @DarkPresence
Added subscriber: @StephenSwaney
I can't quite read the text in the screen shot. Something about a Value Error?
I managed to reproduce this once in 2.90, then not in 2.90.1, now I can't reproduce this at all. Weird.
Added subscriber: @rjg
This report does not contain the requested information, which are required for us to investigate the issue. Please read this guide , it may help you write a bug report that allows us to fix your problem.
Please create a new bug report through Help > Report a Bug in Blender. We expect all bug reports to follow the submission template . Please provide system information (operating system, GPU, driver version), affected Blender version, previous Blender version that worked properly, a short and precise description of the issue, step by step instructions to reproduce it and, if relevant, a minimal .blend file that showcases the problem.
@HooglyBoogly If you should be able to reproduce this, then please reopen the ticket. Currently there are no instructions to reproduce this issue and the screenshot is unreadable (or only with a lot of guess work).
Added subscriber: @Imaginer
It's actually a very high resolution image, if you click on the image then right click and choose view image.
Here is a cropped screenshot of @DarkPresence's screenshot showing the details.
Running
mesh.print3d_scale_to_bounds
(N-Panel > 3D-Print > Transform > Bounds) with an active but not selected object causes this error.Tested on 2.90.0.
@Imaginer You're right, not sure why it didn't display properly the last time I checked. I'll handle this on Monday.
@rjg Thanks.
@Imaginer I've created a proper report in #82760
Thanks @rjg.
