Annotations Panel updates in Right Sidebar 1 Frame delayed #81857
Reference: blender/blender#81857
Operating system: Darwin-19.6.0-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon Pro 5500M OpenGL Engine ATI Technologies Inc. 4.1 ATI-3.10.18
Broken: version: 2.90.1, branch: master, commit date: 2020-09-23 06:43, hash:
3e85bb34d0
If you have two annotations and you start framing forward from the first to the second, the second annotation will show up in the 3D viewport on the correct frame, but the Annotations Panel in the Right Side Panel of the 3D viewport doesn't update until the following frame.
Thank you for taking a look at this!!
Daniel
Added subscriber: @DanielHoughton
Added subscriber: @lichtwerk
Can confirm, refreshes when hovering over the panel.
This looks like a missing redraw. Using the "current frame" button in the outliner works, so I expect the frame offset operator doesn't do proper updating.
Added subscriber: @antoniov
@antoniov It looks like the active frame for the annotation gpencil layer is used for the frame label here, and it's one redraw step behind. That seems like a larger issue in itself, but maybe not?
Anyway, it could be easily covered up by just using
scene.frame_current
for this label, but that might be wrong too. We definitely need Antonio's expertise here.Same is true for
frame_jump
,keyframe_jump
,marker_jump
btw.Might be wrong, but suspect this is because of
BKE_gpencil_layer_frame_get
[which sets the active frame - and is called from drawing...annotation_draw_data_layers
].Not sure drawing code should set data in this way?
I'm going to look at code to see what active frame you get when move.
I have checked and when you move the keyframe, active frame changed, so it's only a problem with the panel refresh.
You can check easily using this python line in the console:
bpy.data.grease_pencils- [x].layers- [x].active_frame.frame_number
When you are in frame
9
, the result of the python above is1
, and moving the cursor over the panel the buton is updated.So, @HooglyBoogly you can add the redraw tag and the panel must be updated as expected.
As side note about the logic behind.
The active frame is set in
BKE_gpencil_frame_active_set()
function. When the frame change is evaluated and the function assigned inbuild_object_data_geometry_datablock()
is called, the frame number is calculated.The function
BKE_gpencil_layer_frame_get()
just try to read the active frame, and if the active frame is not correct, then is recalculated. Usually, this funtion returns thegpl->actframe
because if all is working with no bugs, the active frame is already available. Only if you add new frames or some special cases, theactframe
must be calculated in this function.EDIT: Looking at the debug, it looks the annotations are not working as I explained above. The depsgraph never call the
function, and all is updated inBKE_gpencil_layer_frame_get()
function. Don't know if this is a problem because the draw is done after the panel update or not.We maybe need something like this:
/* get frame to draw */
bGPDframe *gpf = BKE_gpencil_layer_frame_get(gpl, cfra, GP_GETFRAME_USE_PREV);
if (gpf == NULL) {
continue;
/* Add layer drawing settings to the set of "draw flags"
I don't know what is the right code to update the panel, but must be in the comment line above.
