Data Transfer modifier works inconsistently when dealing with Vertex Color Alpha #81914
5 Participants
Reference: blender/blender#81914
Graphics card: GeForce GTX 1060 6GB/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 456.71
Broken: version: 2.90.1, branch: master, commit date: 2020-09-23 06:43, hash:
3e85bb34d0
Worked: -
When using DataTransfer modifier to transfer vertex colors from object to another, vertex color alpha interferes with color transfer. Vertex color alpha seems to work as a mask which is not expected.
(See attached blend file for ready-made setup)
DataTransfer_Vertex-Color-Alpha.blend
Added subscriber: @TMug
#81996 was marked as duplicate of this issue
Added subscriber: @mano-wii
I can confirm.
This occurs in older versions like 2.79 as well.
Apparently the alpha value replaces the original color with white.
I don't know why that happens, it seems to be a bug.
Data Tranfer works inconsistently when dealing with Vertex Color Alphato Data Transfer modifier works inconsistently when dealing with Vertex Color AlphaAdded subscribers: @mont29, @brecht, @lichtwerk
White is the original vertex color on the destination object - which is not being replaced by red because the source layer has alpha = 0 there.
This is because modes other than
Above Threshold
andBelow Threshold
do real Mixing (btw. I guess it would be good to gray out the Mix factor for the threshold ones).Mixing is done premultiplied, see
layerCopyValue_mloopcol
/blend_color_interpolate_byte
and the comment in blend_color_interpolate_byte:Doing color interpolation premultiplied is probably usually the right thing to do (it might be different in the context of DataTransfer modifier?), not sure this is a bug, @mont29 or @brecht might know?
Added subscriber: @FrankieHobbins
To me this looks like what happens when you don't interpolate premultiplied. So I would check if the code is calling this function and that the function is working correctly.
Also, layerCopyValue_mloopcol copying alpha from m1 to m2 rather than using the interpolated alpha is wrong, though I'm not sure that would cause this issue.
Code is called, and I think it does what it advertises: it takes straight input, premultiplies colors with the alpha internally before blending, so you get no color change in the target if the source has another color (but no alpha there).
This is the right thing to do, no? At least this is how layer blending in Gimp etc works afaict.
I think the reason this actually looks "off" in this file is that interpolation of alpha in the viewport on this lowpoly is just not "enough".
It already looks a lot better if you subdivide a bit:
DataTransfer_Vertex-Color-Alpha_subdivided.blend
However, I think there is also something wrong with
: if the combined alpha (after applying the mix factor) is zero, it would just copy the whole color, but alpha should be zero here?P1730: T81914_snippet_one
If that is corrected (otherwise you get popping if a mix factor of one is used), you are right, interpolated alpha should be used:
P1731: T81914_snippet_two
This issue was referenced by
6a5d2f4ea2
3fc97727df
Since
6a5d2f4ea2
and3fc97727df
have been committed, I think the alpha handling is now actually correct.For the viewport interpolation being "off" on lowres [highres works better - see my example file above], I think this deserves to be a separate report.
Will close this one (feel free to comment again though if issues persist - we can always reopen in that case)
