Percent even bevel width type for the bevel modifier - basic design suggestion #81931
Reference: blender/blender#81931
In short, currently theres no width type for the bevel modifier that gives you a bevel that is even on both sides of the original beveled edge but that lets you decide the bevel amount based on the percentual distance of one of the nearby edges. Hence, I think this is something worth getting looked into. Please see the below image or the attached pdf for more detailed explanation of how I think it should work as well as some motivation for why this should be implemented.
Thanks for reading :)
Percent even bevel width type for the bevel modifier suggestion.pdf
Added subscriber: @Olliver
Percent even bevel width type suggestionto Percent even bevel width type for the bevel modifier - basic design suggestionAdded subscriber: @HooglyBoogly
This sort of detailed feature request really belongs on https://blender.community/c/rightclickselect/, not here. Anyway, the policy is not to allow feature requests on the bug tracker.
It's an interesting idea. Although I sort of feel the need for all these width options might be a sign of some other less visible design flaw in bevel. Not sure though.
To me this pretty much seem like a complete design. Ideas coming from the developers dont exactly first post there stuff on rightclickselect, they are first posted as designs - here.
Yes well there are several issues with the bevel modifier currently, one being that the clamp causes all bevels to thrink if you have a bevel go above the threshold, another being that the clamp stops bevels far too soon in some situations (So you cant utelize the whole edge because of the clamp stopping).
Another is that for all edge width types except the current percent doesnt support variable fillets (aka fillets/bevels that change in width between the sweep edges).
Another is that you cant use bevel weights for high precision control due to the float decimal limit for bevel weights while working on very large ranges. Like if you want one edge to be beveled with a width of around X cm and another with a width of around 100x you will need to make the bevel weight for that smaller width edge 0.01 and then you are getting very close (too close in some situations) to the amount of decimals read by the bevel modifier to get a decent amount of control of the width.
So ofc, the Blender team could take the time to fix all those issues. But instead I think its better if they keep there focus on making the long term goals and pushing out other stuff that matter more, but instead both simply the workflow and fix several issues by making another width type based on the percent width type which has its benefits, but that the bevel wont get "stretched" like it does by the current perecnt width type.
Because the current "percent" width type has non of the issues described above and is the only width type that doesnt (Thanks to that it doesnt need clamp and supports variable fillets), but its unusable to create "even"/unstretched bevels without adding support edges or something like that - which is then the hole I want the percent even bevel to fill in.
Is there any other way that I can present the idea to the developers?
Ive posted many ideas on right click select in the past but, some of them gotten a lot of upvotes (Like 30-40) yet without any attention from the devs. Some of them being quite simple like this one, but that would make a big difference for the artist.
Added subscriber: @rjg
If you would intend to implement this yourself, then this would be fine e.g. on DevTalk to discuss it with other developers. If you want other people to implement this for you, then it's a feature request and should be posted on right-click select.
Unfortunately we can't give certain users and their ideas special treatments. The rule that feature requests are off-topic for the bug tracker applies to everyone. If this is something that both the community and the developers consider important and there are developers available to implement this, then it will be picked up. We get far more improvement suggestions and feature requests every day than our developers could possibly implement. Hence it is to be expected that only a very small subset of ideas actually get integrated into Blender.
Aha alright.
Thanks for the elaborate answer :) I understand the situation
Even if it seems like not much happens to stuff on right click select, I expect that's more a function of developers' lack of time than lack of interest in what's posted there. Thanks for understanding.
