Pivot Point in Edit Mode shows black dotted line but pivot point sometimes miss aligned no matter which pivot mode is selected and rotation seems to be miss-calculated #81952
Reference: blender/blender#81952
Operating system: Win 10 Pro
Graphics card: NVidia
Broken: 2.80.0 and 2.80.1
Worked: unknown
Pivot Point in Edit Mode shows black dotted line but pivot point is miss-aligned no matter which pivot mode is selected and rotation seems to be miss-calculated if the object is attached to an armature and with bone poses applied. This is when the Cage and Edit Mode options are selected on the armature modifier for the object. Note the origin of the object and the armature are both set to the same world location.pivot point broken.blend See file example attached.
Added subscriber: @James8569
Added subscriber: @mano-wii
I didn't understand the problem.
You can set the pivot orientation manually from the panel:
https://docs.blender.org/manual/en/dev/editors/3dview/3d_cursor.html#d-cursor-panel
Or you can set the orientation to "Transform" in the properties of the Cursor tool.
Added subscriber: @dfelinto
The file was saved with 2.90, not 2.80.
This report does not contain all the requested information, which is required for us to investigate the issue.
Please submit a new report and carefully follow the instructions. For instance which version this worked previously, and in this case you may want to show with an image what is the expected result, and what you are getting.
