Particle system behaves inconsistently in viewport and render when instance object visibility is disabled #81973
Reference: blender/blender#81973
Graphics card: Quadro P2200/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 441.20
Broken: version: 2.91.0 Beta, branch: master, commit date: 2020-10-21 22:57, hash:
b0f34eee30
Worked: The behavior was different in 2.80
When the instance object of a particle system is disabled in the viewport the particles are also disabled in the viewport. However when the instance object is disabled in render they still appear in the render.
particle_visibility_bug.blend
Added subscriber: @tanderson
Added subscriber: @mano-wii
How different?
Here is the same file adapted for blender 2.79.
particle_visibility_bug_279.blend
The behavior appears to be the same.
It is normal for instances to be affected in the same way as the original object. I don't think this is a bug.
Oops, I misunderstood the problem.
I can confirm that it is different.
And in fact the behavior in the render and viewport should be consistent.
Added subscriber: @zeauro
To be clear, disabling rendering of emitter and original object, instanced as particles, is the most common thing you want to do to render only particles.
Problem in 2.79 was that Viewport was not able to hide the sphere without hiding particles although they were rendered.
Nobody wants to render a unique big instance overlapping all the other tiny instances. Nobody wants a return to that situation.
If you ower
Now, we can disable rendering of the cube and the sphere in viewport and in render without disabling rendering of particles.
For that, we have the local temporary viewport display corresponding to Eye icon.
Use that Eye button instead of the Screen button to hide Sphere and everything will be fine.
Screen button, described as Globally Disabling the objects in all Viewports, is there to check object dependencies through collections and file linking, not to fine tune visibility in Viewport.
Check the file.
particle_visibility_wanted.blend
That makes a lot of sense to me. So the eyeball and the render toggle are consistent here and the monitor/screen allows you to go further in the viewport but there's no analogous option for renders.
I ran into this when an object was being linked in and used in a particle system but it was then hidden in the source file, so the particles were only showing up in renders. Pretty much the situation you described.
For the previous problem with the visibility couldn't that have been resolved by just putting the original object in a collection and hiding that collection?
Thanks for the response.
