Improvements to "Bake Action..." Operator #82168
Reference: blender/blender#82168
With the developments happening in the blender animation module more robust tools and feature are being needed.
The "Bake Action..." operator is a rather useful tool that feels incomplete:
Here are some options that would take it to the next level.
These seem from my ignorance very minor features that would make the operator much more useful in production.
Added subscriber: @LucianoMunoz
Added subscriber: @wbmoss_dev
For (1), would it be sufficient to use the active frame range? If the preview range is ON, then that's the default for the bake range. If OFF, then it would use the non-preview range?
The only problem that i see here is that would be implicit rather than explicit and that is the problem in a lot of areas in blender even if the zen of python says otherwise.
In any case I'd place a little clock watch icon in the panel too that would be turned on if the one in the timeline is on and so on just so its clear to the user what is being done on what range and WHY.
But you're on the right track nevertheless.
For the smart baking levels idea:
Maybe we could support "Baking Sets" where bones grouped together in the same set are keyed together. Then that leaves the proper definition of them to the rigger who knows the rig inside out. The animator can expand upon it if needed for specific uses. To make it more automated, we can provide operators to create the baking sets (based on constraints and drivers on the added bone). These sets can then be cleaned up and fixed by the rigger or animator.
I suppose the more general implementation of "Baking Sets" are normal bone collections which should replace Armature Layers anyways.
Im not against the idea I'm not sure I understand it though.
I was thinking more a levels where you'd have a little number slider that could go "0" only keep the keys from the current selected baked controls, "1" this and whatever bones have direct influence over this will transfer its keys, you get the idea.
Maybe -1 to get keyframes from every thing in the armature ? (i don't know how useful would that be)
What do you think, i feel this way is simple and requires 0 set up for the user just chose what they need on a case by case basis.
The problem with levels is that the rig can have many levels of indirection. For Pierrick Picaut's rigs, he creates intermediate bones all the time. For a Head bone that optionally follows the neck, there are intermediate bones which may never be seen or keyed by an animator. I imagine Rigify rigs are similar (I'm not familiar with Rigify).
What if we used level 2? But that's the same problem. If you are given a rig, then you don't know the proper amount of indirection (levels) to bake. And the number of levels changes on a per-bone basis too.
What if we used a really big number? That effectively creates a key where any keyframe exists on the rig.
That's why I think I'd work if there is an intermediate bone that doesn't have a key good then its not considered and only consider the ones that do.
The levels will give you an explicit way of troubleshooting when you don't get the exact result you expect and be able to control it.
And yes a really big number will effectively give you a key wherever it exist in the rig, expected.
To add to this the default should be 1. Normally its the control / object and whatever directly connects to it that we'll pick up keys from (whether direct parent or constrain)
I'll make test patch for the levels idea.
Can you give use cases for these two? I'm only aware of one example: using an NLA layer to switch to IK arms and completely replace a segment of FK animation. Then bake with the expectation that the IK switch is transferred too. In this case, 5 and 6 are the same thing and can probably be better named:
Merge all NLA
. What are the cases for (5) that is independent of (6) and vice versa?I'm not sure how they are the same?, 6 does involve the improvement from 5 though.
As it is now, if you use the bake action tool even in just one action (not pushed) custom properties data gets lost. It needs to be considered as well.
is being able to merge several nla pushed actions to one:
Example I created an action for walking and one for running y put them both in the nla mix them etc, now I just want all the data merged to the original animation so I can easily modify it.
yes!
Added subscriber: @feldlaufer-4
being able to bake custom properties is urgeeeeent !!! cause atm there is simply no way to do it? why would we animate properties and not want them baked after? do we know when the new features could be available?
I am removing the
label. This is under the general rule that Design and TODO tasks should not have a status.If you believe this task is no longer relevant, feel free to close it.
