Keymap is not exported with the correct encoding #82292
Reference: blender/blender#82292
Graphics card: GeForce RTX 2070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 452.06
Broken: version: 2.90.1, branch: master, commit date: 2020-09-23 06:43, hash:
3e85bb34d0
The exported keymap is not encoded with UTF-8 but an encoding depending on the locale. This produces a file which cannot be properly imported afterwards.
The
keyconfig_export_as_data
should specify the encoding when usingopen()
.Exact steps for others to reproduce the error
operator-to-reproduce-bug.py
Added subscriber: @Guai_Wo_Ge_EMM
Added subscriber: @rjg
The files you've attached appear to be encoded with GB2312 for simplified Chinese. Blender requires these files to be encoded with UTF-8. Additionally the
keymap.py
appears to be generally broken withNULL
bytes at the beginning and seemingly corrupted output at the end of the file.Could you please explain how you created these files and the exact steps to reproduce the issue? If Blender has saved these files that can't be imported, then this would be a bug. However, should you have manually edited the keymap and saved it with the unsupported encoding, then this is not a bug in Blender.
EMM.py
QQ录屏20201101191923.mp4
我没有做其它多余的操作,我点击导出之后,立刻点击导入,然后它就出现了这样的报错,而且两个报错还不同,我也不知道还有其它什么地方注意的,会不会是因为我使用的中文系统导致的呢,另外附上我操作的视频
我还发现一个问题,就是新建一个 keymap 选择它也会出现BUG
@Guai_Wo_Ge_EMM Unfortunately the video in your last comment doesn't play for me. If you could re-upload it, that would be very helpful.
Just to avoid any misunderstandings, is it correct that you're doing the following steps?
Was the first keymap that resulted in the export/import error created by editing one of the built-in keymaps through Edit > Preferences > Keymap? Is the
EMM.py
or.py
(from your original report) the keymap what you get after exporting and you're trying to import this file again? Iskeymap.py
what you get after attempting to importEMM.py
or.py
?Added subscriber: @jenkm
I don't know what the "Blender-PME" addon is, but you use non-English names in it, I think so.
It could be something like this {86c4ca71ef18}.
Yes, I'm using a PIE plugin, it can use custom UI.
Its forum address is this:https://blenderartists.org/t/pie-menu-editor-1-18-0/662456/3680
是的,我正在使用一个PIE插件,它能使用自定义UI.是这个原因吗
它的论坛地址是这个:https://blenderartists.org/t/pie-menu-editor-1-18-0/662456/3680
I can reproduce the import error by attempting to import
EMM.py
. This is caused by the pie menu entries as @jenkm said and as I've noted in my first comment the encoding for these characters is not in UTF-8 but seem to be GB2312.It appears that the Blender-PME add-on doesn't handled encoding properly and stores non UTF-8 characters in the keymap. We can't provide support for the paid third-party add-on,however Blender shouldn't let an add-on store invalid characters in the keymap either.I'll try to reproduce this issue through the Python API.
Edit: It's Blender's fault.
Changed status from 'Needs User Info' to: 'Needs Developer To Reproduce'
@Guai_Wo_Ge_EMM As a workaround I've edited the
EMM.py
file which can now be imported. The Chinese characters have been replaced with the (poorly machine translated) English words and it's been saved with UTF-8 encoding.EMM_edit.py
Thank you, the file you sent can be imported, thank you very much, in addition to this bug I have feedback to the plug-in developers there, should be resolved!
谢谢您,您发的文件可以导入了,十分感谢,另外这个BUG我已经反馈到插件开发者那里了,应该会得到解决
I've tried to intentionally break the keymap through the Python API, but haven't been successful so far. Will continue to investigate.
It seems that the problem is caused when an operator has a string property, there is a shortcut registered for it in the keymap and the shortcut uses a value for the operators string property that is not UTF-8 encoded. However, I can't get a keymap to export after assigning e.g. Chinese characters to the property in the keymap preferences. It gives the following exception:
As of now I cannot reproduce the exact error from the original bug report with my current system configuration, but I have an idea. Since the error references
cp1252.py
Blender always seems to be using the system locale to determine the encoding. Reproducing the exact error from the original report may be possible with a different system locale configuration, which then presumably fails to import it later on. I would guess that in order to reproduce this bug you would have to set Windows' system locale to Simplified Chinese, which then results in code page 936 being used. This would then have GB2312 encoding applied to the input, which is what I've seen in the keymap included in the bug report.If anyone wants to test this and investigate further, below is a script that implements a simple operator which is added to the keymap when registered.
I think I found the issue. The code page error in my last comment means that Blender isn't using UTF-8 for the export on my system either. The function
that writes the keymap doesn't set the encoding to UTF-8. The encoding should be explicitly set in Python'sopen()
function.Currently:
Possible fix:
Edit: @jenkm was spot on with his comment.
@rjg
@jenkm Yes, I know. Would've found/verified the problem quicker if I checked
or greppedopen(
first, instead of attempting to reproduce the reported error condition.Changed status from 'Needs Developer To Reproduce' to: 'Confirmed'
Cannot import the same version of exported shortcuts 无法导入同一个版本导出的 快捷键to Keymap is not exported with the correct encodingThis issue was referenced by
4988f5f39c
f7320c3bf1
