Unable to add extra objects if an empty is selected #82405
Closed
opened 2020-11-04 18:34:14 +01:00 by Antti Katajamäki · 8 comments
Graphics card: GeForce GTX 970/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 457.09
Broken: version: 2.91.0 Beta, branch: master, commit date: 2020-11-04 00:13, hash: blender/blender@101c3d4ce4
Worked: 2.82
Addon Information
Name: Extra Objects (0, 3, 7)
Author: Multiple Authors
If an empty object is selected (active) one cannot add roundcube, torus objects, gears, pipe joints, diamonds or extras.
  1. Open blender
  2. Enable extra objects add on
  3. Add empty
  4. Try to add roundcube, torus objects, gears, pipe joints, diamonds or extras.
extra_objects_issue.blend
blender_debug_output.txt
blender_system_info.txt
**System Information** Operating system: Windows-10-10.0.19041-SP0 64 Bits Graphics card: GeForce GTX 970/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 457.09 **Blender Version** Broken: version: 2.91.0 Beta, branch: master, commit date: 2020-11-04 00:13, hash: `blender/blender@101c3d4ce4` Worked: 2.82 **Addon Information** Name: Extra Objects (0, 3, 7) Author: Multiple Authors **Short description of error** If an empty object is selected (active) one cannot add roundcube, torus objects, gears, pipe joints, diamonds or extras. **Exact steps for others to reproduce the error** 1. Open blender 2. Enable extra objects add on 3. Add empty 4. Try to add roundcube, torus objects, gears, pipe joints, diamonds or extras. [extra_objects_issue.blend](https://archive.blender.org/developer/F9197818/extra_objects_issue.blend) [blender_debug_output.txt](https://archive.blender.org/developer/F9197820/blender_debug_output.txt) [blender_system_info.txt](https://archive.blender.org/developer/F9197822/blender_system_info.txt)
Added subscriber: @Antti-1
Added subscriber: @rjg
I can confirm this issue. This is caused by the check ('some-string-here' in context.active_object.data.keys()) and (self.change == True):, because an Empty doesn't have data and you can't call keys() on None. This bug can be found in:
  • add_mesh_beam_builder.py
  • add_mesh_gears.py
  • add_mesh_gemstones.py
  • add_mesh_honeycomb.py
  • add_mesh_pipe_joint.py
  • add_mesh_pyramid.py
  • add_mesh_round_cube.py
  • add_mesh_star.py
  • add_mesh_supertoroid.py
  • add_mesh_torus_knot.py
  • add_mesh_twisted_torus.py
  • Wallfactory.py
This also affects the Bolt Factory add-on:
  • BoldFactory.py
This also affects Geodesic Domes:
  • third_domes_panel_271.py
I can confirm this issue. This is caused by the check `('some-string-here' in context.active_object.data.keys()) and (self.change == True):`, because an *Empty* doesn't have `data` and you can't call `keys()` on `None`. This bug can be found in: - add_mesh_beam_builder.py - add_mesh_gears.py - add_mesh_gemstones.py - add_mesh_honeycomb.py - add_mesh_pipe_joint.py - add_mesh_pyramid.py - add_mesh_round_cube.py - add_mesh_star.py - add_mesh_supertoroid.py - add_mesh_torus_knot.py - add_mesh_twisted_torus.py - Wallfactory.py This also affects the Bolt Factory add-on: - BoldFactory.py This also affects Geodesic Domes: - third_domes_panel_271.py
Robert Guetzkow self-assigned this 2020-11-04 19:01:09 +01:00
Added subscriber: @cwolf3d
Robert Guetzkow was unassigned by Vladimir Spivak 2020-11-05 20:28:37 +01:00
I tested this patch, everything works. You can apply it. Thanks for your work.
Robert Guetzkow was assigned by Vladimir Spivak 2020-11-05 20:30:10 +01:00
This issue was referenced by 6975199131
This issue was referenced by 69751991311a165e97a48ea67ed60e2c6022ee63
Reference: blender/blender-addons#82405
