Objects have become randomly invisible in certain tabs #82443
Reference: blender/blender#82443
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 452.06
Broken: version: 2.91.0 Beta, branch: master, commit date: 2020-11-04 19:21, hash:
29780b8101
Worked: Worked in all versions, but the problem seems to have appeared in version 2.9 and is sporadic.
Objects have become randomly invisible in certain tabs.
Other information
I have not been able to reproduce this bug outside of my project. Therefore, I took my project and I stripped all the objects not related to the problem.
During the time that I got the problem, I was mainly working in the Compositing and Shading views and selecting and changing the visibility of the objects in the Outliners. I cannot tell exactly how the problem triggered. During my work, on many occasions, I found out that I could not focus on certain objects anymore (by using the dot on the numeric keypad). This is where I noticed that these problematic objects were not visible anymore in the view that I was working. I bypassed the problem by using another view. In this case, the Layout view was still working while I had problems in the Modeling view. Eventually, I had to reload the blend file without the UI to clear the problem and continue normally.
Loading the blend file and unchecking “Load UI” in the load dialog does a reset in the UI. That clears the problem. It appears to me that the problem is UI related.
I believe the problem has already disappeared once without a reason, but it came back later. I cannot tell why, but all other times when it happens, I needed to reload the file without the UI.
Beyond the fact that the object is not visible in a particular view, the selection functions related to the object are also not functional. For example, doing View | Frame Selected (dot on the numeric keypad) does not adjust the view to the object. Furthermore, the move gizmo widget is not even shown. It is really as if the object did not exist at all a the problematic view. However, in other views, we do not even notice there is a problem because it works correctly.
Although I keep resetting the UI by reloading the blend file and clearing the “Load UI” option, this problem keeps coming back without an apparent reason. You can validate the problem with the project file included, but reproducing the steps that lead to the problem is another story.
ObjectVisibilityIssue.blend
Added subscriber: @SebBlender
Added subscriber: @deadpin
This is because your "Modeling" tab is set to "local view" link and so is focusing just on Sphere_Visible:
Hit
to exit local view and then re-center your view to see all the objects.Thanks, that works! Although I used the / quite often, I never saw this possibility in my project. Therefore, this is not a bug, at least in the code, but in the design, it is another thing.
Following that, I would like to bring a suggestion. Blender is a particular software in terms of UI. Since 2.8, it is more standard and easier to use. Its unique design may confuse people sometimes. I’m probably not alone to have encountered that.
I suggest that you make it clearer when the local view is used. There are two examples that I want to highlight.
In edit mode, it appears obvious because the icon menu at the left changes and some other visual cues as well.
In the Unity game engine, the play mode has confused many developers. They were doing modifications and they lost their modifications once returning to the normal mode. To make things more obvious, Unity has introduced a feature that turned all the interface of the editor to a different color. That way, it was obvious that Unity was in play mode.
Furthermore, I would like to add that I got confused a few times when editing locally in other projects. After a while, I did not remember that I was still in the local view and I was wondering why it did nothing when clicking the other objects in the Outliner. It was not a major problem, but more a glitch in the user experience. Now that I know that, I’m more aware.
To come back to this problem that I reported above, I never suspected this possibility because I never thought that I entered the local view. My reference of entering the local view is sometimes more in my head than what I see on the screen. I must have entered the local view accidentally. The original project had objects of the space with stars and the view looked like the space. The objects were either small or extremely large. I was working mainly in render mode. Nothing so obvious to notice an object being isolated.
Here is some solution to this design issue.
Do you think, you could add that (making the local view and more obvious) as a task to modify the UI?
Added subscriber: @lichtwerk
Thanks for the report, feedback is always welcome, but the issue reported here is a request for modified/improved behavior and not a bug in current behavior. Closing as this bug tracker is only for bugs and errors.
For user requests and feedback, please use other channels: https://wiki.blender.org/wiki/Communication/Contact#User_Feedback_and_Requests
For more information on why this isn't considered a bug, visit: https://wiki.blender.org/wiki/Reference/Not_a_bug
