Eevee's AO shades even outside of the distance #82462
2 Participants
Reference: blender/blender#82462
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 456.71
Broken: version: 2.90.0, branch: master, commit date: 2020-08-31 11:26, hash:
0330d1af29
Eevee's AO creates certain amount of gradients and shading even outside the Distance area. I'm not refering to the typical screen space oclussion problems.
For example, if you turn Distance to 0, instead of getting the same result as having AO turned off, you get a gradient. Here's how it looks with a flat lit, diffuse scene:
Distance 0, Factor 0:
Distance 0, with a Factor of 10 to exagerate the effect:
Even if the gradient is subtle with Factor 1, it can be very visible in certain workflows. Example: There are no other screen space effects in this image, other than AO, which has small distance anyway but this gradient spans the entire image (I'm aware that 360 is not officially supported but still, the gradient itself is not a fault of the 360 stitching and can be a problem for regular images too
If this is a limitation of the method, may I suggest a clamping slider of some sort for very light values? Thank you❤
Open the file and turn AO on and off
AOBUG.blend
Added subscriber: @SecuoyaEx
Added subscriber: @lichtwerk
Can confirm.
No idea about the underlying method used here, so might be a Known Limitation, but cannot find it documented anywhere.
Not sure what you mean, treat zero as AO disabled?
No, I mean a slider to clamp the light values to white. Given that the most interesting, more "proper" AO stuff happens in darker values.
Here's a mockup with a factor of 5, with a factor of 1 it would be even more subtle.
Unclamped:
Clamped:
I would do this with the compositor but there are two other problems.
One is the AO pass doesn't take into account Bent Normals, Bent Normals gives different AO with different HDRI. I think this is another bug worth reporting
The other is that the diffuse pass always includes the AO, so there's no way to exclude it properly, given that the AO is supposed to be multiplied only against the enviroment light and the result summed to the rest (as it should), not multiplied over the entire image. Without an enviroment light pass or light groups, is cumbersome to do with the current View layer system, losing all performance benefits
