UV Smart Project works wrong #82540
Closed
opened 2020-11-09 15:31:54 +01:00 by Tomasz Muszynski · 23 comments
Graphics card: GeForce RTX 2080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 456.71
Broken: version: 2.91.0 Beta, branch: master, commit date: 2020-11-08 13:39, hash: 06dac0a453
Smart UV unwrap does not react on UV seams
Use Smart UV unwrap with seams on some co-planar edges.
**System Information** Operating system: Windows-10-10.0.19041-SP0 64 Bits Graphics card: GeForce RTX 2080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 456.71 **Blender Version** Broken: version: 2.91.0 Beta, branch: master, commit date: 2020-11-08 13:39, hash: `06dac0a453` Worked: (newest version of Blender that worked as expected) **Short description of error** [Please fill out a short description of the error here] Smart UV unwrap does not react on UV seams **Exact steps for others to reproduce the error** [Please describe the exact steps needed to reproduce the issue] [Based on the default startup or an attached .blend file (as simple as possible)] Use Smart UV unwrap with seams on some co-planar edges. ![SmartUV-ProblemAGAIN.JPG](https://archive.blender.org/developer/F9245605/SmartUV-ProblemAGAIN.JPG)
Added subscriber: @TomaszMuszynski
Member
Added subscriber: @lichtwerk
Member
Member
Mind sharing an example file where this happens?
Look at the attached image.
Those "pinkish" lines are seams. And they are completely ignored by smart_project .
Recently Devs have changed something in the smart_project operator cause it gives error when using parameters that are included in current offcial 2.90.1 API and no info in the Changelog that something has been developed recently ( with 2.91 version I have to use Radians instead Degrees ).
You can download my add-on ( sorry for the quality of the code inside it ) and see that I had to use other parameters (watched from the operator call in Bblender ) than are mentioned in official API.
https://github.com/muchasty/UV-Tools/blob/master/LightmapAutoUV.py
Look at the attached image. Those "pinkish" lines are seams. And they are completely ignored by smart_project . Recently Devs have changed something in the smart_project operator cause it gives error when using parameters that are included in current offcial 2.90.1 API and no info in the Changelog that something has been developed recently ( with 2.91 version I have to use Radians instead Degrees ). You can download my add-on ( sorry for the quality of the code inside it ) and see that I had to use other parameters (watched from the operator call in Bblender ) than are mentioned in official API. https://github.com/muchasty/UV-Tools/blob/master/LightmapAutoUV.py
Here is my project file: https://www.dropbox.com/s/2m7shajh2gy32ns/USA-Lazienka.rar?dl=0
Member
Philipp Oeser self-assigned this 2020-11-09 18:17:54 +01:00
Member
Maybe I am misunderstanding, but Smart UV is not supposed to take Seams into account?
Instead, islands are defined by by Angle Limit?
https://docs.blender.org/manual/en/latest/modeling/meshes/editing/uv.html
So, if this was never working [which I think it wasnt], then this sounds more like a feature request than a bug.
Will have to close (but feel free to comment again if this was working at some point - or if this is a misunderstanding on my side)
Regarding the change between 2.90.1 and 2.91: smart UV was ported to C, see 850234c1b1
Since this is a different subject - having to use radians instead of degrees - than the original report though, I would kindly ask to report this separately [agree, this should be mentioned in the release logs]
Maybe I am misunderstanding, but Smart UV is not supposed to take Seams into account? Instead, islands are defined by by Angle Limit? https://docs.blender.org/manual/en/latest/modeling/meshes/editing/uv.html So, if this was never working [which I think it wasnt], then this sounds more like a feature request than a bug. Will have to close (but feel free to comment again if this was working at some point - or if this is a misunderstanding on my side) Regarding the change between 2.90.1 and 2.91: smart UV was ported to C, see 850234c1b1 Since this is a different subject - having to use radians instead of degrees - than the original report though, I would kindly ask to report this separately [agree, this should be mentioned in the release logs]
I am disappointed with that kind of bug filtering !
Please use 2.90.1 and you will see how the smart_project() should work !
Look at the attached image and find the difference ( this is from 2.90.1 with nicely cuts made by seams )
according to the previous image from 2.91Beta !
I am disappointed with that kind of bug filtering ! Please use 2.90.1 and you will see how the smart_project() should work ! Look at the attached image and find the difference ( this is from 2.90.1 with nicely cuts made by seams ) according to the previous image from 2.91Beta ! ![Przechwytywanie.JPG](https://archive.blender.org/developer/F9248042/Przechwytywanie.JPG)
Member
Changed status from 'Archived' to: 'Needs Triage'
This issue was referenced by 05a2382c08
This issue was referenced by 05a2382c08402b250d6b5c4105b449f4474f6cf2
Member
Added subscriber: @ideasman42
Member
Sorry @TomaszMuszynski for getting that wrong and thx @ideasman42 for the fix!
No problem. Let's go forward and do not look back. :)
I hope that it will be fixed soon cause it is crucial for me for making with my add-on well working lightmaps for UE4.
Thank you.
No problem. Let's go forward and do not look back. :) I hope that it will be fixed soon cause it is crucial for me for making with my add-on well working lightmaps for UE4. Thank you.
Member
Well, fix is in, should be in tomorrows build from https://builder.blender.org/download/ (and will also be in 2.91 release)
> In #82540#1051377, @TomaszMuszynski wrote: > I hope that it will be fixed soon cause it is crucial for me for making with my add-on well working lightmaps for UE4. Well, fix is in, should be in tomorrows build from https://builder.blender.org/download/ (and will also be in 2.91 release)
THANK YOU !
THANK YOU !
What is going on?
Problem came back in release blender-2.91.0-e580c188533c-windows64
What is going on? Problem came back in release blender-2.91.0-e580c188533c-windows64
Member
Changed status from 'Resolved' to: 'Confirmed'
Member
@ideasman42, looks like 9296ba8674 brought this back?
This issue was referenced by e01bf7a92e
This issue was referenced by e01bf7a92ecad3c64d0b1ae176f402d2638e246c
Reference: blender/blender#82540
