CLI documentation for macOS doesn't work on non-bash shells #82644
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
Reference: blender/blender-manual#82644
Pagename:
advanced/command_line/launch/macos
instead of
echo "export PATH="$PATH:/Applications/Blender.app/Contents/MacOS" >> ~/.bash_profile
(which doesn't work - i have a mac and it won't work )
it should be
export PATH=$PATH:/Applications/Blender.app/Contents/MacOS
(which works)
Added subscriber: @LuckyChris
documentation does not workto documentation - small errorAdded subscriber: @ankitm
This will stop working the moment you restart a shell session: new tab or new window or terminal relaunch.
Better solution is to add a note for 10.15+ macOS where zsh is the default shell. So .bash_profile would not take effect.
documentation - small errorto CLI documentation for macOS doesn't work on non-bash shellsyou are right, sorry, new proposal:
Add to the PATH on Mac OS X 10.8 Mountain Lion and up
Open up Terminal.
Run the following command: sudo nano /etc/paths.
Enter your password, when prompted.
Go to the bottom of the file, and enter "/Applications/Blender.app/Contents/MacOS"
Hit control-x to quit.
Enter “Y” to save the modified buffer.
Close the terminal and open a new one so that the new path will be used.
This issue was referenced by 7410
