Define name of built-in attributes #82693
6 Participants
Reference: blender/blender#82693
Naming rule for attributes
In both cases abbreviations are to be avoided. If they eventually happen, should be lower case for the built-in attributes. For user defined attributes they can be decided on a per-case basis.
Reference
Written_Like_This
MaterialX: lowercase .e.g
materialassign, variantset
(example)Blender datablocks uses "Title Case" and PascalCase:
Built-in attributes:
density
position
radius
rotation
scale
temperature
Design presented on: https://wiki.blender.org/wiki/Source/Nodes/Modifier_Nodes#Attributes
Added subscriber: @dfelinto
Added subscriber: @pablovazquez
I think we should try to keep names shorter, since they will be used a lot in expressions.
Possibly supporting multiple names for built-in attributes. A longer, more descriptive name and a short-form version.
Proposal:
P
,position
, (alsolocation
for compatibility?)R
,rotation
(alsoorientation
,orient
for compatibility?)S
,scale
Other names we could have by default for points/particles:
age
density
temperature
N
,normal
V
,velocity
r
,radius
index
up
Added subscriber: @SteffenD
Can we get a set of rules for the names? Should the names be lower case always/usually. What about spaces? Should underscores be used instead? Do we want to enforce these rules (could be useful for expressions)?
What do we do if existing vertex groups do not follow these rules, are they just not accessible in geometry nodes?
I think giving attributes multiple names is calling for trouble. Having a single name will make things simpler. Maybe it makes sense to provide tooltips for some common attributes like P, but not sure if it is worth it.
Added subscriber: @brecht
Talked to Dalai and Bastien about this, summarizing some of the points I made:
P
,Pref
,Cd
) or a lowecase name (uv
,st
,width
,pscale
, ..)density
andtemperature
), because that is the OpenVDB convention.Personally my recommendation is not to use abbreviations at all, which makes it a choice between capitialization or all-lowercase. Either works for me, depends if we prefer to be consistent with other default Blender data names, or if we consider it harmful or helpful that geometry attributes have a distinct naming convention. If we do change it to lowercase, I'd recommend changing default uv map and vertex color names to lowercase as well.
Thanks for the feedback. I don't have a strong opinion on whether capitalization or all-lowercase should be the convention then.
Also should mention that vertex groups are capitalized and I imagine will be accessible as attributes in geometry nodes. And those names are matched with bone names for armature deform. Changing to lowercase may just be more trouble than it is worth.
The volume grids inconsistency is not great. We could also capitalize/lowercase on import/export there. For render engines that directly read OpenVDB or USD files any renaming on import/export is also a pain, but I guess they have to deal with that regardless of the convention we choose.
@pablovazquez and I came up with this proposal:
Reference
Written_Like_This
I'm fine with that proposal.
Added subscriber: @Sergey
Background: I was randomly pointed to this task.
Here are two easy steps to dramatically improve quality of the proposal.
Have up-to-date conclusion in the task description. Just similar to what we do for reports. Make it easy for everyone to see what's what.
Explicitly cover abbreviations. If they are unused at all, state so. If they are forbidden, state so. If there are any case when they might appear from (user attributes, for example) make explicit whether it is only first letter to be capital, or all of them (within the abbreviation).
Migrated the text to the wiki: https://wiki.blender.org/wiki/Source/Nodes/Modifier_Nodes#Attributes
@Sergey thanks for the feedback. I addressed your 1st point. For the second I feel it is a bit premature to set a rule to a case I can't even think already. So I phrased in a way that leaves some leeway for when it comes to that while covering it for built-in attributes.
