Huion Kamvas 13 viewport rotation with pen side buttons and pen pressure doesn't work properly #82711
Reference: blender/blender#82711
Graphics card: AMD Radeon RX 5700 XT ATI Technologies Inc. 4.5.14736 Core Profile Context 20.11.1 27.20.12033.2007
Broken: version: 2.92.0 Alpha, branch: wintab-coalesced-logging, commit date: 2020-10-24 04:52, hash:
d7379449f9
Worked:2.91
Report created as requested by @PrototypeNM1 in #82430
viewport only rotates when the pen makes contact with the screen and pen pressure is always constant
system log.txt
P1768
Added subscribers: @PrototypeNM1, @Diogo_Valadares
@Diogo_Valadares I [updated the build ]] with additional logging, could you recreate the bug and paste the console log [ https:*developer.blender.org/paste/edit/form/default/ | at this link again?
Same link as before, can you check if the issue is still present and upload logs if so?
@Diogo_Valadares Can you follow up on my last question, the bugtracker policy is to close reports that are inactive for a week. Note that if you update the log without commenting I might not see the update.
sorry, I didn't see the notification.
the pen pressure is fixed, but to rotate the viewport I still need to touch the pen on the display.
P1819
Added subscriber: @TruggUdden
i am having a similar issue with my huion kamvas 20 pro. i cant rotate or manipulate with the buttons but the tip selection works.
Added subscriber: @heini
@PrototypeNM1
so, I tested the new build , it kinda looks like the navigation is fixed but it also looks like cursor clicks are offset from the real one by a lot.
2020-12-21 18-41-42.mp4
Also, I think sometimes after rotating the view, the camera kinda snaps to a slightly different angle from when you release it .
I just experienced a similar issue on gimp (https://youtu.be/OoPiBoD23dw) and I discovered the source of the problem. it seems like it'ss some incompatibility with multiple monitors, It still is only present in this last build tho.
The problem is probably a bug in Huion's Wintab driver when using multiple monitors/scaling, as the issue isn't present for Wacom tablets. The most recent build uses Wintab more directly than before, which is necessary for high frequency events but also means issues in Wintab drivers are more likely to cause problems.
I'll give this a more thorough look when other issues wind down, but the solution might just be "use Windows Ink, it's more stable".
@Diogo_Valadares since the symptoms are fairly different from the initial report, would you mind opening a new report describing the new problem?
created at #84179
