addons not showing up in user #82862
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
2 Participants
Reference: blender/blender-addons#82862
Operating system:
Graphics card:
Broken:
(example: 2.79b release)
Added subscriber: @jilliyeah90
hi i am trying to install a addon but its not showing up in my user bar how can i fix it?
Added subscriber: @rjg
This report does not contain the requested information, which are required for us to investigate the issue. Please read this guide , it may help you write a bug report that allows us to fix your problem.
If you need help learning or using Blender, please post a question on one of our [community websites ]], for instance https:*blender.stackexchange.com/ , https:*blenderartists.org/ or the [ https:*blender.chat/channel/support | #support channel on Blender chat . The bug tracker is only for bug reports.
In case you believe that you've found a bug, please create a new bug report through Help > Report a Bug in Blender. We expect all bug reports to follow the submission template . Please provide system information (operating system, GPU, driver version), affected Blender version, previous Blender version that worked properly, a short and precise description of the issue and step by step instructions to reproduce it.
The most common issue is that you're download a repository on GitHub as a .zip where the actual add-on is in a subdirectory. Check the installation instructions for the add-on and download the correct file, which is presumably located on the release page.
Once you've installed the add-on through Edit > Preferences > Add-ons by clicking on the Install button, you also have to enable it. If the add-on was properly installed, Blender should show it in the list of installed add-ons. You need to tick the checkbox in front of its name to enable it.
