I can't get my reference image to load in Blender #82921
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#82921
Operating system: Windows 10
Graphics card: Nvidia GTX 1660
Broken:2.8
(example: 2.79b release)
Okay, so weird fix...
1} Go to Edit>preferences
2} Set the clip Alpha to 0.005 instead of the usual 0.004 and you can see your image.
3} Make sure your "overlays" feature on the top right corner is turned on!
I can't see my reference image in my viewport. Blender notices there's something there but can't show it for some reason.I was even in the object properties and increasing its size and everything, thinking it would work but still, nothing works except for the above-mentioned fix.
Hope you guys can fix this technical error.Thanks for the support!
1} Hit shift+A
2} Go to Image> Reference> Load the reference image
3} You should see a empty appear in the collection box but you don't see a image.
Added subscriber: @Mechastorm
Added subscriber: @Bodi
Sounds like it was alpha clipping. What was the image, can you share?
Added subscriber: @rjg
As @Bodi said, please provide an example file that demonstrates the problem. I couldn't reproduce this in any Blender version based on the currently provided information
