FBX exporter not exporting textures if material is not principled shader #82967
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
2 Participants
Reference: blender/blender-addons#82967
Operating system: Linux-5.9.8-arch1-1-x86_64-with-arch 64 Bits
Graphics card: Radeon RX 590 Series (POLARIS10, DRM 3.39.0, 5.9.8-arch1-1, LLVM 11.0.0) X.Org 4.6 (Core Profile) Mesa 20.2.2
Broken: version: 2.92.0 Alpha, branch: master, commit date: 2020-10-27 14:27, hash:
blender/blender@90e12e823f
I have a textured mesh using a material not using principled shader, instead it uses a diffuse node, but the textures are not exported.
I could change the material setup to use principled shader manually, is there an automatic way to convert diffuse and glosy materials to principled?
Textures_not_exported_to_fbx.blend
Thanks in advance!
Added subscriber: @JorgeGasconPerez
I have found more information in the console, the traces of the FBX exporter say:
Added subscriber: @rjg
Thank you for your report. This is a known limitation and documented in Blender's manual . Only the Principled BSDF is supported for the purpose of exporting a material.
Aah, thank you very much for your quick response. Robert!!
Ok, I will try to convert these materials to principled shader, thanks a lot.
