Undo can start affecting modifier settings in edit mode. #82991
5 Participants
Reference: blender/blender#82991
Broken: 2.91 (
6c6a5a72c2
)Worked: 2.90
In 2.90 or earlier versions, if you change a modifier setting in edit mode and undo or redo, the modifier changes are ignored, so undo only changed modifiers in object mode. The same if you add or remove a modifier, that was also ignored in edit mode as seen in #63367. That's not always the case anymore in 2.91. Something can trigger undo to start working with modifiers in edit mode, but it behaves inconsistently as it wasn't intentionally implemented. When this bug is triggered, new modifiers can be added and removed in edit mode with undo/redo, but they're added or removed in the wrong order, similarly to what happens in object mode in #75541. Also sometimes if you change a modifier setting in edit mode, then do something else and undo, both actions will be undone at the same time, similarly to what used to happen with tool settings. What is expected is for undo and redo to ignore modifiers settings in edit mode, but when the bug is triggered this does not happen. In object mode, undo behaves mostly like it should, undoing only one thing at a time, and also works well with modifiers settings. I have managed to reproduce it many times already in different steps, two of them involved adding and removing keyframes to trigger it, other didn't. Sharing the file doesn't work because the bug doesn't happen if you save and reopen the file you have to trigger it again.
Exact steps for others to trigger the bug
Add subsurf modifier to cube.
Increase to 2 subdivisions
Tab to Edit Mode
Select a vertex
Move the vertex
Change the modifier setting from catmull clark to simple
Keyframe the number of viewport subdivisions
Remove the Keyframe
Move the vertex again
Undo until you see the modifier setting change from simple back to catmull clark - that's where the bug is kind of triggered
Redo all - the keyframe will be added back in the wrong order as it should not be there after the last redo step
Remove that keyframe again.
Increase number of subdivision
Change from simple to catmull clark
Move the vertex
Undo twice
Redo twice
Change simple to catmull clark
Move the vertex
undo/redo - the bug fully is triggered, now on undo/redo affects any modifier setting change and also new modifiers, which shouldn't happen in edit mode.
Note
Just a note that adding and removing a keyframe isn't required to trigger the bug, just a way I've found to trigger it more often. Here is a video in which all I had done to trigger the bug was change modifier settings, transform the mesh and undo/redo in some order inbetween, no keying done. Unfortunately trying to do the steps of this video from scratch won't trigger the bug. Because I can't know the order of undo/redo I did to trigger it then, as I could only film the undo history.
Undo_modifier_edit mode_bug_nokey.mp4
Added subscriber: @lichtwerk
These would be good though
@lichtwerk I've written the steps from the video up to the point that the bug is triggered and a bit after.
Added subscriber: @mano-wii
There are too many steps.
I know the intention was to describe the video but is it possible to replicate the bug with fewer steps?
Unfortunately the scenario described is too time consuming for us to track down, we require the bug reporter to narrow down the problem.
If there are many steps to reproduce the problem, please attach a .blend file saved before the bug occurs, so only a few steps are needed to trigger the bug.
Yes, the first time the bug triggered for me was in just a few steps. I had just downloaded 2.91 to test the new subdiv modifier options and then after a minute I noticed that undo/redo was affecting modifiers. All I did to trigger the bug then was to change modifier settings, transform the mesh and undo/redo all mixed in some order. I wasn't recording as I wasn't expecting some bug to occur to know when did I undo/redo.
@mano-wii As I've mentioned, sharing the file does not work, since the bug vanishes when saving and reopening the file.
Undo affecting modifier settings in edit mode.to Undo starts affecting modifier settings in edit mode.Undo starts affecting modifier settings in edit mode.to Undo can start affecting modifier settings in edit mode.@lichtwerk @mano-wii .
After some hours I have found and written simpler steps to reproduce the bug. Please have a look.
Added subscriber: @iss
I can reproduce this after following steps exactly.
version: 2.92.0 Alpha, branch: master, commit date: 2020-12-06 15:58, hash:
a90504303e
Added subscriber: @mont29
The fact that non-editmode operations cannot be undone in Edit mode is old known issue (see #63367 e.g., we have several similar reports, also affects Armature edit mode etc.).
Fact that new undo backend code partially/wrongly start to store global undo steps while in edit mode is more a glitch than anything else.
I don't get it. Why is it not considered a bug? What I'm reporting is that the known issue actually stops happening, contrary to what's expected, which makes undo in edit mode unpredictable. I'm not telling you to make undo work with modifiers in edit mode, I'm asking you to make it behave like in the known issue and like previous versions (2.90, or 2.83). If this undo in edit mode change from 2.90 to 2.91 was intentional, why would you do that? And if it is intentional you should have closed the known issue as invalid since it's not what happens anymore in 2.91 and 2.92 and make this the new known issue, which is not what I want. We need undo to be consistent and ignore modifier changes in edit mode like stated in the Known Issue, or be fixed to work in edit mode. The way it is now is just very undesirable to say the least.
This report does not add anything really to known situation, bug is that non-edit changes get ignored undo-wise while in edit mode, as already reported in #63367 etc.
