Crash after Startup #83072
Reference: blender/blender#83072
Operating system: Win 10
CPU: Ryzen 5 3600
Graphics card: Gigabyte RTX 3080 Gaming OC
Broken: 2.83 (11-Nov-2020 15:54), Blender 2.81 (05-Dec-2019 11:52), Blender 2.91 (25-Nov-2020)
Worked: Blender 2.81 (last time it worked is 04-Nov-2020)
When I start Blender, the window opens for a split second second. I already tried the 'blender_debug_gpu.cmd' and got an EXCEPTION_ACCESS_VIOLATION error.
The GPU driver is up to date and Windows Update as well.
Start Blender
blender_debug_output.txt
blender.crash.txt
Added subscriber: @Giebel
Added subscriber: @rjg
Please attach the debug logs and (potentially) crash log you get from running
.Added subscriber: @David_H
Not OP, but I also have this problem.
Graphics card: NVIDIA GeForce RTX 2070 SUPER (Driver date: 2020-11-06)
Broken: blender-2.91.0-windows64
Worked: Never (first installation on this computer).
I've attached the blender.crash file produced when I try to launch the application, and the blender_debug_output file produced when running
.blender.crash.txt
@David_H Your issues appears to be the same as #72098, if you also have an integrated GPU. Please tests if the workaround explained in #78799 allows you to start Blender.
@Giebel Please test this as well.
@rjg I don't have an integrated GPU and already tried the energy/ high performance modes (which didn't have any effect).
Regarding the OS update: I installed the update Windows 10, Version 20H2 on 15-Nov-2020 and some minor updates. I also updated my Bios (if this could have an influence on it).
Regarding the monitors: I have two monitors, but didn't change how they are connected.
@Giebel Could you please upload the log files you get from running the
?Oh, I'm sorry, I really thought, I already it id... Here it is:
@Giebel Thank you. Could you please repeat this with Blender 2.91 or 2.92? This will also produce a crash log with a stack trace in
C:\Users\[your username]\AppData\Local\Temp\[project name].crash.txt
Is it necessary to delete version 2.83 before?
As I see the version 2.92 is available as a portable version. So here is the new file:blender_debug_output.txt
@Giebel If you use the portable version (*.zip) then no installation (or deinstallation) is required. Thank you. Could you also upload the
C:\Users\Jan\AppData\Local\Temp\blender.crash.txt
?blender.crash.txt
@Giebel Thank you for the file. Are you absolutely certain that your CPU doesn't have an integrated GPU, because that log files look very similar to the ones that have the issue with Intel + Nvidia? What is your CPU model?
I do have an Ryzen 5 3600 and if I'm not mistaken, it has no integrated GPU.
Could you check if this still happens when unplugging one monitor?
It's the same with either only monitor 1 or only monitor 2 plugged in.
blender_debug_output_monitor1.txt
blender_debug_output_monitor2.txt
Good news. I found the problem!
I reinstalled the Nvidia graphics driver through GeForce Experience and Blender works again in every version.
Thank you very much for all your effort!
Added subscriber: @lichtwerk
Changed status from 'Needs User Info' to: 'Resolved'
Thx getting back, closing then.
@rjg Thanks for your help. The workaround in
#78799
fixed my problem.
