Node wrangler error showed: no matching image found #83283
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#83283
Operating system: WIN10Node Wrangler Blender
Graphics card: RTX 2070
Broken: 2.91 release
I try to export texture to a plane, but it kept showing error: no matching image found. Can anyone help?
I'd already enabled Node Wrangler.
(first time)Select Principle BSDF and Material OutPut
1)ctrl + shift +T
2) go to d:/(the folder I put texture)
3) hit "principled texture setup"
4)showing error: Select Principled BSDF
(second time)Select Principle BSDF and Material OutPut
1)ctrl + shift +T
2) go to d:/(the folder I put texture) at the same time unable "Relative Path"(I researched for some articles mentioning about this method)
(Third time)ONLY Select Principle BSDF
1)ctrl + shift +T
4)showing error: NO MATHCING IMAGES FOUND
PLZ HELP MEEEEEEEE!
Added subscriber: @MonLes
Added subscriber: @fernandavaz
This comment was removed by @fernandavaz
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
Added subscriber: @johncara
I had the same problem and for me worked to just rename the image that I import by adding the name of their function at the end ex. '' blackshader1.jpg -> blackshader1.Diffuse.jpg , or Roughness.jpg or whatever you are importing it for.
I fixed this by downloading a texture pack that had all the images. If your node structure requires multiple images you need all the images.
