Blender benchmark error #83421
legacy module
Rendering & Cycles
legacy project
1.0.0-beta.2
legacy project
Blender Benchmark
legacy project
Priority::Normal
Status::Archived
Status::Confirmed
Status::Duplicate
Status::Needs Triage
Status::Resolved
Type::Bug
Type::Design
Type::Report
Type::To Do
Reference: archive/blender-benchmark-bundle#83421
Operating system: win10 pro
Graphics card: rtx 3070
CPU: AMD 3900x
Broken: Blender open data benchmark
2.90 GPU CUDA OPTIX
**Before I overclocked my GPU, both GPU and CPU test run well.
After I overclocked gpu with msi afterburner, when running benchmark app, it shows WHOOPS! didn't receive benchmark jason data.
But it still can benchmark my CPU.
**error id 8e688f3106ad47c5a152788279afaa72
Added subscriber: @Electricalfork
OPTIX is fine. Only CUDA will show this error
Added subscriber: @rjg
@Electricalfork If the issue is caused by overclocking then this is not a bug in Blender. If you're operating the hardware outside of its specification it may happen to not work properly. Undo the overclocking and check if the problem still occurs.
Added subscriber: @espectalll
Oh hey, this seems very similar to the issue I just reported while using an AMD card with OpenCL, #83431. No overclocking applied.
I cannot reproduce the issue. Does this still occur with the current Benchmark software?
Added subscriber: @lichtwerk
