WRL import #83428
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#83428
Not relevant
Broken: version:
blender/blender@13c820d87b
Worked: 2.79
Addon Information
Name: Web3D X3D/VRML2 format (2, 2, 5)
Author: Campbell Barton, Bart, Bastien Montagne, Seva Alekseyev
Importing wrl file does not work properly.
The same file imported fine in 2.79, but gives back this error when importing in 2.91
Added subscriber: @Hybryda
Added subscriber: @rjg
This error was introduced in
6aa8e130ef
in 2018 when renaminglamp
tolight
, which also unintentionally modifiedclamp
toclight
.This issue was referenced by
ff83176c7f
This issue was referenced by blender/blender-addons-contrib@d71985e901
Added subscriber: @DaveA
This is not fixed in 2.93
Barrel.wrl
Changed status from 'Resolved' to: 'Confirmed'
@DaveA You're right the Python API changed and
use_clamp_x
is no longer available. The commit only fixed the incorrect renaming. Thank you for noticing and providing a test file.If there are more parts of the add-on that haven't been updated to the current Python API, then this might take some time.
Edit: The model can be imported when removing the outdated code, but the add-on definitely has to be checked for other instances of incorrect API usage. Additionally,
use_clamp_x
anduse_clamp_y
don't seem to have a direct replacement. The clamping/clipping may need to be recreated with nodes.The add-on appears to depend on the old API in multiple areas. This will not be a quick fix.
0573bc7dae
