GLSL 'clamp' issue? #83494
8 Participants
Reference: blender/blender#83494
Operating system: Linux 5.9.10-arch1-1
Graphics card: NVIDIA GTX 980Ti 455.45.01
Broken: 2.91, 2.92 master
Worked: ???
According to GLSL spec, clamp(x, a, b) == min(max(x,a), b). So then, clamp(0, 1, 0) should yield 0. But that doesn't seem to be the case, at least on my system. With this node setup:
...the output should be black. However...
Eevee material preview:
Eevee render:
Cycles render:
Exact steps to reproduce error
Observe difference between material/render with Eevee vs. Cycles. Every time Eevee is used (material preview and render), the ouput will be white, though it should be black. Cycles render produces correct result.
Sample blend file:
clamp_issue.blend
Added subscriber: @Stan_Pancakes
Added subscribers: @fclem, @brecht, @mano-wii
Thanks for the report, but I would not say that this is a bug.
It is expected that users set the maximum value to something always greater than the minimum.
If they don't, the result is unpredictable and will depend on the engine.
Apparently in Eevee it was decided that the minimum value prevails while in Cycles it is the maximum value.
Although consistency is more appreciated, this is something to decide outside the bug tracker. (https://wiki.blender.org/wiki/Communication/Contact#User_Feedback_and_Requests).
So I'm closing the report for now.
(Cc @fclem, @brecht)
I cannot reproduce. It feels like it's an issue with the Nvidia driver. Are you using proprietary driver? please attach your
system_info.txt
.We could patch the GLSL code but it seems like this is a quite basic thing to expect from driver to properly implement a clamp!
@mano-wii, please don't do that. The two clamp options aren't called "Range" and "Implementation-defined". They're called "Range" and "Min Max".
@fclem Of course. See also https://www.shadertoy.com/view/Ms33R4 . I see this:
system-info.txt
Added subscriber: @dfelinto
I cannot reproduce it either on:
Operating system: Linux-5.4.0-56-generic-x86_64-with-debian-bullseye-sid 64 Bits
Graphics card: GeForce GTX 1080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 450.80.02
As in, I don't get the Cycles black render either.
@dfelinto I've attached an example file in the description, so that we're on the same page.
Added subscriber: @Foaly
I get the same result as @radcapricorn.
Quote from the GLSL 4.6 spec:
So if EEVEE wants to implement this consistently across platforms, I'd argue the clamp function cannot be used.
Or we can make it undefined as well in the documentation. I assume the Min Max type exists only for performance reasons anyway?
Changed status from 'Archived' to: 'Confirmed'
We don't want to expose undefined behavior to users, so this is a bug then.
(right, with the sample file I can reproduce - I couldn't with only the clamp node directly linked to the Material output)
This issue was referenced by
fe5d2448c6
