Change Brush size does not show Falloff gradient anymore #83603
Reference: blender/blender#83603
Operating system: Darwin-20.2.0-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon Pro 575 OpenGL Engine ATI Technologies Inc. 4.1 ATI-4.2.11
Broken: version: 2.92.0 Alpha, branch: master, commit date: 2020-12-07 22:51, hash:
ab9952e55f
Broken: 2.81
Worked: 2.80
Caused by
be985bdde2
This was not the case in 2.79 or 2.80
Turns out whenever radial control is used for something other than PROP_NONE, PROP_PIXEL, PROP_DISTANCE, it draws with the (falloff) gradient, in our case [brush size], it draws without. Think this is useful information which does not really distract?
Added subscriber: @Kent-Davis
Hello?
Added subscriber: @mano-wii
I also can't see the black Falloff circle here.
It must be by design.
I'm not sure if it's really a bug.
Added subscriber: @lichtwerk
It does display when a texture mask texture https://docs.blender.org/manual/en/dev/sculpt_paint/brush/texture.html#texture-mask is specified.
You can set one to pure white to get the desired effect, but maybe this could be done by default yes.
In Fact, 2.79 and 2.80 still did that, so I would confirm this.
Will also check on this.
Push the 'F' key doesn't appear falloff black circle show display.
Push the 'Shift+F' yes show number and falloff black circle show display.
Push the 'Command+F' yes show number and fall black circle show display.
That is not TEXTURE PAINT.
Added subscribers: @PabloDobarro, @JulienKaspar, @Jeroen-Bakker, @ideasman42, @pablovazquez
Seems like this was a somewhat intentional change in
be985bdde2
Also see this comment in D5889
So whenever radial control is used for something other than
PROP_NONE
,PROP_PIXEL
,PROP_DISTANCE
, it draws with the (falloff) gradient, in our case [brush size], it draws without.Not sure I can follow that logic (think this is useful information which does not really distract), but will let module members decide...
Use this to always show it:
P1853: #83603 snippet
CC @PabloDobarro
CC @JulienKaspar
CC @pablovazquez
CC @Jeroen-Bakker
CC @ideasman42
Falloff (black middle circle) [F] key not appear show displayto Change Brush size does not show Falloff gradient anymoreYes correct.
Using gradients to define a curve in the UI is rarely useful (you can't differentiate gray scale values with enough precision to determine the shape of the curve). This is why the curve preview with the line was added when changing the strength.
I consider this an UI design discussion, but in my opinion, the gradient falloff should be always hidden (maybe only show it multiplied on top of an alpha texture when it is being used).
@PabloDobarro Do you have your own Macintosh?
@lichtwerk Thank you for your support to change rename correct. I am not good english to explain but why @PabloDobarro put invalid without communication to me.
I ask him do they already inspect for Macintosh.
@Kent-Davis, apparently the "Brush size gradient falloff" no longer showing was a design choice and not a bug.
The same is seen in other systems (not only Macintosh).
Since it is not really a bug (but something that was decided), the report has been closed.
@mano-wii Thank you for explain me.
