After effects import #83606
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
2 Participants
Reference: blender/blender-addons#83606
Operating system: Window 10
Graphics card: NVIDIA GeForce
Blender Version (2.9)
Broken: (after effects import)
(example: 2.79b release)
It will not allow me to import objects to after effects
Added subscriber: @9dimeblack
Please Help !!!!!!!!!
Added subscriber: @rjg
This report does not contain the requested information, which are required for us to investigate the issue. Please read this guide , it may help you write a bug report that allows us to fix your problem.
In case you believe that you've found a bug, please create a new bug report through Help > Report a Bug in Blender. We expect all bug reports to follow the submission template . Please provide system information (operating system, GPU, driver version), affected Blender version, previous Blender version that worked properly, a short and precise description of the issue, step by step instructions to reproduce it and, if relevant, a minimal .blend file that showcases the problem.
Are you trying to use the Export: Adobe After Effects (.jsx) add-on? Please write a new report and described exactly what you're doing, step by step, and how this doesn't work as expected.
