Add Mesh: Extra Objects --> Single Vertex creates invisible vertices in Blender 2.91.0. #83627
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
2 Participants
Reference: blender/blender-manual#83627
Pagename:
addons/add_mesh/mesh_extra_objects
Create a mesh object.
Enable the addon (Add Mesh: Extra Objects).
In Edit Mode (vertex mode), type SHIFT + A to bring up the Add Object panel and click Single Vert --> Add Single Vertex. You can verify with Statistics that the number of vertices are increasing, but the vertices cannot be seen.
Added subscriber: @hatinacat2000
Added subscriber: @rjg
I can't reproduce this issue, the vertex is added and is visible. You need to be in vertex select mode though, as otherwise a single vertex is invisible. That has nothing to do with the add-on though.
This report does not contain the requested information, which are required for us to investigate the issue. Please read this guide , it may help you write a bug report that allows us to fix your problem.
In case you believe that you've found a bug, please create a new bug report through Help > Report a Bug in Blender. We expect all bug reports to follow the submission template . Please provide system information (operating system, GPU, driver version), affected Blender version, previous Blender version that worked properly, a short and precise description of the issue, step by step instructions to reproduce it and, if relevant, a minimal .blend file that showcases the problem.
