Edit Mode Crash on Shrink Edge Loop #83643
Reference: blender/blender#83643
Operating system: Happens on Mac 11.01 Big Sur, & Win 10 latest update
Graphics card: NVIDIA 960 & MBP, late 2015
Broken: blender-2.92.0-9b11a7776f2a-windows64
Worked: not sure, as I do not have multiple versions of Blender on this machine
Exact steps for others to reproduce the errormonochidium lunum.blend
This is the point at which the application crashed regardless of the system (Mac or PC)
A visual of the crash
Added subscriber: @snakeblade
Added subscriber: @HDMaster84
can confirm with the reported file with:
Operating system: Linux-5.8.0-2-amd64-x86_64-with-debian-bullseye-sid 64 Bits
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 450.66
Broken: version: 2.92.0 Alpha, branch: (modified) but not in that area, commit date: 2020-12-09 06:33, hash:
ebe4bf6286
But then I compiled the newest version and the crash does not happen.
Fixed: version: 2.92.0 Alpha, branch: master, commit date: 2020-12-10 17:07, hash:
a7fcca1062
can you confirm that?
Added subscriber: @rjg
Changed status from 'Needs User Info' to: 'Resolved'
This issue was fixed by
37bf71ad04
.@snakeblade Just as a tip, in case you weren't aware, you can use {key Shift Alt LMB} to select edge loops.
Thanks, Gentlemen! - I will download the latest daily build and test. Also thanks for the select tip. I'm a lefty (using LMBvs. RMB as the primary button) and wonder if that works on the right side of the keyboard? Often I can't get the shortcuts to work.
@snakeblade It depends on your keymap, but if it's the default Blender keymap then it should work. When in doubt check Edit > Preferences > Keymap.
Confirming it's also fixed on the DEC 11 build blender-2.92.0-caed4849d090
Thanks again - shortcuts def don't all work when LMB is the primary button, but that's another bug. Thanks, Blender Team
@snakeblade You need to switch the {key LMB} for {key RMB}, if you set your selection to {key RMB}. For you it would be {key Shift Alt RMB}, so this is not a bug. You need to place your mouse cursor on an edge though, in case that wasn't clear.
