Particle instance modifier broken #83886
Closed
opened 2020-12-17 12:19:30 +01:00 by Philipp Oeser · 7 comments
Member
Operating system: Linux-5.9.11-200.fc33.x86_64-x86_64-with-fedora-33-Thirty_Three 64 Bits
Graphics card: GeForce GTX 970M/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 455.45.01
Broken: version: 2.92.0 Alpha, branch: Unknown, commit date: Unknown Unknown, hash: rBUnknown
Broken: 2.91
Worked: 2.90.1
Caused by 8398050695
Once a Particle instance modifier get added to an object with valid settings, all geometry disappears
particle_instance_modifier_broken.blend
  • Open .blend
  • Inspect no instances of the monkey are to be found :(
**System Information** Operating system: Linux-5.9.11-200.fc33.x86_64-x86_64-with-fedora-33-Thirty_Three 64 Bits Graphics card: GeForce GTX 970M/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 455.45.01 **Blender Version** Broken: version: 2.92.0 Alpha, branch: Unknown, commit date: Unknown Unknown, hash: `rBUnknown` Broken: 2.91 Worked: 2.90.1 Caused by 8398050695 **Short description of error** Once a Particle instance modifier get added to an object with valid settings, all geometry disappears **Exact steps for others to reproduce the error** [particle_instance_modifier_broken.blend](https://archive.blender.org/developer/F9514824/particle_instance_modifier_broken.blend) - Open .blend - Inspect no instances of the monkey are to be found :(
Author
Member
Added subscriber: @lichtwerk
#85323 was marked as duplicate of this issue
Philipp Oeser self-assigned this 2020-12-17 12:19:56 +01:00
Author
Member
Will check on this
Will check on this
Author
Member
Fix incomming
Fix incomming
This issue was referenced by 3fc07d1e74
This issue was referenced by 3fc07d1e7482a6472bf6e34616ebe7b616189274
Author
Member
Author
Member
Added subscriber: @AlchemyCGI
Thomas Dinges added this to the 2.92 milestone 2023-02-08 16:15:38 +01:00
2 Participants
Reference: blender/blender#83886
