Active Spline SubPanel Disappears when editing Bezier Curve (when deleting vertex) #83948
Reference: blender/blender#83948
Graphics card: Intel(R) Iris(R) Plus Graphics 640 Intel 4.5.0 - Build 26.20.100.7986
Broken: version: 2.92.0 Alpha, branch: master, commit date: 2020-12-18 23:13, hash:
6942dd9f49
Broken: version: 2.91.0, branch: master, commit date: 2020-11-25 08:34, hash:
0f45cab862
The active spline panel goes away completely during certain curve editing tasks. I have found older reports on the active spline, but those are marked resolved, and this is a specific simple new error that is slightly different.
Make a new "General" blend file. Delete default cube. Add a Curve > Bezier. Tab to Edit. Subdivide curve. Delete the newly added (middle) vertex and at that moment the "Active Spline" goes away.
Re-subdividing doesn't bring the panel back, nor does extruding. Clearly the curve is still present (see image below), and the spline is still present and active, but just a vertex was removed on the curve (that wasn't even an original vertex).
Forgot to add that I absolutely love Blender and all the work you do!!
Added subscriber: @AquilaTheEagle
Added subscriber: @rjg
I can confirm the behavior. One of the handles or control points needs to be selected afterwards to get the panel back. The problem is that
bpy.context.object.data.splines.active
is not set after the middle control point / spline is deleted, hence there is no active spline. The panel drawn byDATA_PT_active_spline
usesCurveButtonsPanelActive
that has the following condition for poll:Hence the panel isn't displayed as
curve.splines.active
isNone
.I don't think this can considered a bug. The panel is meant to be displayed when there is an active spline and at that moment there isn't one.
This behavior is quite similar to the behavior of the active object with regards to selection and deletion.
Wait . . it is not that simple. On both the daily build and 2.91, selecting a handle, or doing anything does NOT bring the panel back for me.
Also, just deselecting all the handles in edit mode before deleting does not make the panel disappear.
Changed status from 'Archived' to: 'Needs Triage'
I can't reproduce the problem in 2.91 and 2.92 then. What I've done is the following:
That deselecting all handles doesn't make the panel disappear is expected, as just like e.g. with objects there will still be an active object. This a bit of a Blender quirk, but quite consistent across all object types (active != selected).
I think I tracked it down a little further . . If I BOX SELECT any vertex, it does NOT reappear. Also, pressing "a" to SELECT ALL after deleting does NOT make it reappear. I tried BOX SELECTING the whole handle (With the arms) or just the central vertex, but neither works.
But if I CLICK the center handle, then it DOES bring back the panel. I didn't expect that BOX SELECTING vs. CLICKING would have a different outcome here.
The confusion makes sense, but this really is expected, and it works like this elsewhere in Blender too. Imagine your object has 7 different splines and you box select all of them, which one should be active? Because the choice is completely arbitrary, Blender currently prefers to not make the choice at all. It's the same in object mode, edit mode, etc. Your object with one spline is just a trivial example of this same behavior. There is a task for this, #82359, but it will require some design discussion, as it's pretty fundamental behavior to change and has more implications that you might think.
Got it. Thanks for thinking about it! The multi-select makes sense. But BOX SELECTING a single spline or vertex should probably have the same behavior as clicking, right?
I suppose that could be a special case. Often it's simpler to keep behavior consistent though, so that it's more predictable in more complicated cases.
