change keymap for loop and ring select #84265
2 Participants
Reference: blender/blender#84265
Graphics card: GeForce GTX 1080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 456.71
Broken: version: 2.91.0, branch: master, commit date: 2020-11-25 08:34, hash:
0f45cab862
Changing keymap for loop and ring select from double click to the conventional alt+left click not working
Whatever I do, I can't seem to be able to set the loop select to alt+lmb, the problem with double click is that when working with a huge file that the computer is barely handling, double click becomes laggy, I have to try to do the operation several times, not to mention that extending with shift double click becomes almost impossible to achieve.
Added subscriber: @GeorgesDahdouh
Added subscriber: @rjg
It seems you're not using the default keymap of Blender. Are you using a modified version of the Industry Compatible keymap? Perhaps I've misunderstood your report, but if the issue is just with the assigned shortcut, then the performance will not change by using a different key combination as the underlying operator is the same. Assigning a different shortcut should still work of course and if it doesn't then this is a bug. If you're using the IC keymap the problem is likely that the shortcut is already in use for another operator.
Edit: I should also note that these entries might be using different options, thus performing different operations. You would have to open the detail section for this though.
