Library Override: Parent-child relation not working for some objects #84313
6 Participants
Reference: blender/blender#84313
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 460.89
Broken: version: 2.91.0, branch: master, commit date: 2020-11-25 08:34, hash:
0f45cab862
Worked: no info yet
Parent-child relation is not working for two objects in a particular scene with library overrides. The relation info in the object properties show the correct empty as parent, but the objects don't move with the parent. However, the parenting works correctly in the source file.
I recorded a video of what I'm doing:
https://youtu.be/B-D80YNR_r0
"MOD_Locust_Cockpit_v007_bE.blend" is the source file acting as a library. Everything works as expected.
"LibraryOverride.blend" is the blend file where I linked the collection and made a library overrided. The two objects "Locust_Cockpit_Console_New" and "Slice.010" don't move with the parent "LCT_Cockpit_Root". Only after clearing the parent and parenting again it works. This also did not work with the original file. The attached files are heavily reduced in complexity so I could share them. Also, when I make the library override again with the reduced files it is working out of the box, so some problem must have been carried over from the original files. I hope this helps to identify a possible problem.
LibraryOverrideProblem.zip
Added subscriber: @B_Engstler
Added subscriber: @rjg
The
nvoglv64.dll
is part of Nvidias driver, but this might be a red herring. Could you please try to simplify your project(s) as much as possible so that it only contains the bare minimum to reproduce the problem and attach the file(s) to your report?Crash with EXCEPTION_ACCESS_VIOLATION after parenting objects with library overrideto Library Override: Parent-child relation not working for some objectsI changed the task description, as I could not reproduce the crash caused by the nvoglv64.dll, and this is perhaps unrelated to the other issue with library overrides. If I find out more to the nvidia bug I'll post it seperately. The attached blend files are already greatly reduced in complexity.
Trying to find out more I noticed that the trouble starts when I use the shift+s pie menu to snap the root of the overridden objects to the 3D cursor. For some reason the "Offset" was on in the "adjust last operation" menu, but I never noticed as the menu was always collapsed. I have no idea how I can fix it afterwards or how I can access that "offset" property to turn it off per object, other than clearing the parent and parenting again? If this is not a bug it is at least a usability problem. An info in the "Relations" section of the object properties would be the minimum I'd expect, unless I too ignorant and don't know where to look at :)
Edit: I'm sorry if this starts to feel like spamming already, but not using the offset option only apparently solved the problem after snapping, but continued after moving the root again manually. I'll have to avoid library overrides altogether for now, as I've spent way too much time to try to make it work :(
Added subscriber: @unwave
Some override making methods retain a linked object as a parent. It is not a parent-child relationship not working but a parent-child relationship with a wrong parent.
parent = object.parent
if parent and parent.library:
object.parent = bpy.data.objects.get(parent.name)
Thanks a lot for that code! It really solved the problem. I'm very interested under which circumstances the parent-child relationship is maintained to a linked parent after overriding. I'm not aware that I have done anything differently to these two objects than to the others. And the UI lacks any kind of information if the parent is in the same file or in the linked file. Perhaps some more documentation on the "under the hood" of linking and overriding would help a great deal.
Anyway, your are my hero of the day :)
Added subscribers: @mont29, @lichtwerk
I also cannot redo this from scratch, also tried the snapping (with or without the Offset option)
@unwave : you were mentioning that
Could you shed some light on this? This could really help finding reproducable steps here [without repro steps from provided files, this is going to be hard to solve I am afraid]
I am setting this to
, but also getting @mont29 in the loop early (since it might ring a bell for him?)Trying to think of ways to proceed here.
I think we really need a reproducable case of
Can anybody provide this?
Added subscriber: @Threedio
{F9880328If I'm understanding the original error (part of a class of issues related to parenting & overrides) }I have a simple reproducible case, attached in a ZIP. Here are the steps I took to create it:
Made a file called mickey.character.blend which will be our mouse head
create a new file called bugtest.parent.blend which will be our scene that contains our mouse head
open mickey.character.blend
open bugtest.parent.blend
Now here is where it gets interesting. This script will NOT fix the issue:
But this script WILL fix the issue:
Also interestingly, if you run the second script to fix the issue, then undo everything in the undo history, the issue is STILL fixed even though you undid the action of the script.
Nothing special here, your linked spheres in
are parented to the linked head, not the local override.Now you also need to create overrides for those sphere objects, and then remap their parent pointers to the override head. You could do this by hand, but the
Resync
operation is here to take care of that automatically (right-click menu in the Outliner, on your override collection).Note that in 2.93 this should be handled fully automatically, during .blend file loading those cases will be detected, and the resync process will be run where needed (see #83811).
Oh gosh I wish I had seen that resync feature, that would have saved me a lot of trouble :) Yes it totally works of course. Thank you Bastien.
