Geometry Nodes: Point Distribute Node Methods #84330
Reference: blender/blender#84330
The goal of this task is to summarize the design and implementation choices made for the Point Distribute Geometry Node. To clarify, I'm new to Blender development so this post is not meant to be authoritative at all, just as a place to collect ideas.
Use Cases
Two guiding use cases for the Geometry Nodes project can be seen on the project page.
Scattering Pebbles
Trees and Flowers Scattering
Both use cases highlight the importance of weight painting for artistic control over the distribution of points. For example, the weights in the image below govern the distribution of
Large Pebbles
.Point Distribute Methods
This section covers the already implemented Point Distribute Methods. For the most recent refactor of the Point Distribute code see: https://developer.blender.org/D10104
Random Sampling
This method does uniform random sampling for each triangle of the mesh. Uniform sampling has the effect of creating gaps and clusters, as can be seen in the image below. For some uses cases this doesn't matter, but for others this might be undesirable. This is the motivation for the second method, Poisson Disk sampling.
Node inputs
Geometry
: the mesh on which the points will be distributedDensity Max
: a float that is multiplied with the Density AttributeDensity Attribute
: refers to which "weight paint" map to use, these weights range from 0->1Current Implementation
What's nice about this algorithm is that it's fast. A small thing to note is that this is not uniform random sampling on the mesh. For example, if a triangle is large enough, such that
triangle.area * density_max * sum(vertex_weights) / 3 > 1
, the triangle will always contain a point. When doing uniform random sampling over the entire mesh there's always a chance that triangles contain no points, no matter how large the triangle is.Poisson Disk Sampling
Poission Disk sampling is useful when you don't want points to be too close, or you don't want large noticeable gaps in the sampling pattern. A Poisson Disk point set is often said to have "blue-noise characteristics". This image shows the difference between uniform random sampling and a Poisson disk sampling (image source ).
Node inputs
Geometry
: the mesh on which the generated points are projectedDistance Min
: the Poisson radius, no points will be closer than thisDensity Max
: refers to which "weight paint" map to use, these weights range from 0->1Implementation
First scatter points randomly on the mesh. Then loop over all points in order and for each point first check whether the point was already eliminated, if not eliminate all its neighbors. Neighbors are found using a range search in a KDTree.
Possible Future Distribute Methods
Feel free to leave suggestions or use cases.
Clustered Sampling
Example:
Use cases
Node inputs
Implementation
Volume Sampling
Use cases
Node inputs
Implementation
Variable Radius Poisson Disk Sampling
Use cases
Node inputs
Implementation
Poisson Disk Sampling with Geodesic Distance
Use cases
Node inputs
Implementation
Randomly scatter objects without intersecting other objects
Note: this doesn't really fit the
Point Distribute
node, but I've included it because it's relatedDescription
Use cases
Node inputs
Implementation
Added subscriber: @victorlouis
Added subscribers: @HooglyBoogly, @grosgood
@victorlouis
First off, thumbs up, plus one, love token, whatever, and running with this. Your enthusiasm is wonderful to behold.
Second off, don't lose sight that the distribution has to work in an animation without popping or temporal disruption. They may be 'point clouds' in a flat, one-frame sense, but they are really noodles of spaghetti running through time - and look like a model of laminar flow.
I built your D9949 patch last night (ummm... early this morning) and compared its behavior, side-by-side, with the random distribution method - both on stretching and contracting geometry, typical in animation.
compare.mp4
The random distribution on the right is steadier, and benefits from stabilization work @HooglyBoogly did a little while ago (D9832). Particles pop in and out as contraction and stretching take place - and that grates - but, on the whole, a particle stays put for the duration of its time on the surface. On the other hand, there is a lot of jitter in your implementation thus far - and yes, I know it is far from done. I wanted to wave the temporal flag early in your game so that it is in play. As Sherlock Holmes oft-times said to Dr. Watson: "Watson. This seems to be a three-pipe problem." So 'tis here. Have fun with it!
Added subscriber: @KenzieMac130
I feel like animation deformation should work on top of the generated point cloud rather than having to make sure the every algorithm adopted is coherent over temporally deforming geometry. In a good distribution points will inevitably have to be repacked when the surface area changes. It makes much more sense to process it once and deform the results.
Imagine this is someone's arm and the points are hair: it doesn't make sense to deterministically regrow the hair from scratch every frame while the arm bends. It would be better to generate the hair in base pose, deform the arm and the roots of the hair, and apply any simulations on top of those changes.
@grosgood I've thought about the stability and for the
Poisson Disk
method it seems really hard to achieve, because the points influence each other so much. For theRandom
method there's no dependence between points. Also points are sampled per triangle independently so deforming the mesh doesn't matter as much, you can just add/remove points in triangles whose area changes.Yuksel's algorithm however does have an interesting and relevant property that allows for progressive sampling.
I'm not entriely sure whether we could use this property to increase stability under mesh deformation though.
Added subscriber: @brecht
For stability under deformation, there's a few distinct use cases, and they have different solutions.
One is how to make the distribution more stable as the mesh coordinates and even topology change, for when the users is editing the mesh and doesn't want the results to completely change on every minor edit. Some distribution algorithm changes are possible to accommodate this, though in the end the quality of distribution is more important and perfect stability is simply impossible.
The second is where you are deforming the source mesh in an animation and want a stable distribution, for hair or instances that are attached to the mesh. In this case you want the distribution to be identical, and ideally only generated once for performance. No distribution algorithm changes will solve this, it's a matter of always using the same undeformed mesh for distribution.
A third use case would be where you want to do some kind of level of detail, frustum culling, or other incremental generation based on the camera. It's possible to have a distribution algorithm that generates locally stable results, where mesh coordinates or topology beyond a certain distance have no influence.
A fourth is where you want to dynamically add more points. For example to continuously emit particles a random distribution is usually fine. A progressive Poisson distribution would make sense if you want to e.g. grow plants over time.
I think the use case being referred to by @grosgood is the second one. For that problem, we really needed a dedicated task because it goes quite deep. The current particle system handles this using a data layer with original undeformed coordinate. Using it either to generate the distribution, or to map an existing (manually edited) distribution from undeformed to deformed coordinates. A similar system is needed for geometry nodes, though the best UI for that is not obvious.
Geometry Nodes: Point Distribute Node Design & Implementationto Geometry Nodes: Point Distribute Node MethodsDistribute method design proposal for point child. https://developer.blender.org/T84816
Archiving this because it is not actively being investigated.
