Instructions to get object location API reference is incorrect. #84427
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
Reference: blender/blender-manual#84427
The instructions in this section explain how to get the API reference for the object location: https://docs.blender.org/api/2.91/info_api_reference.html#simple-data-access
If you follow the instructions in the second paragraph, the Blender GUI context menu option isn't called "Online Python Reference", but "Online Manual" which points to the GUI manual and not the API reference (unless I misunderstood how to get to that from the Blender GUI): https://docs.blender.org/manual/en/2.91/scene_layout/object/properties/transforms.html
Maybe a previous version of the GUI manual had references to the API's?
Recommend rewriting the second paragraph in this section to point to this API reference: https://docs.blender.org/api/2.91/bpy.types.Object.html#bpy.types.Object.location
Added subscriber: @norulesjustfeels
Just realized that I had to enable the Python Tooltips in the display preferences to see the tooltip. I don't think I saw that anywhere in the API docs, so it might be a good idea to add that explicitly since it looks like all the API docs assume both Developer Extras and Python Tooltips are enabled.
This bug can be closed.
Added subscriber: @rjg
The manual has a page on this, but it appears that it is slightly outdated as we now have a dedicated option for the Python tooltips. I will create a separate report for this.
Added subscriber: @Blendify
I committed an update to both the user manual and API docs
