Image Editor don't display correct image during rendering at very high resolution #84578
Reference: blender/blender#84578
Following issue with high resolution rendering: #82042, #82591
In recent alpha build when rendering with both options CPU and hybrid GPU+CPU the image inside image editor during rendering is different than the same image after rendering, and also both of them are different than saved image on the disk.
(As a sidenote - threshold to trigger this behaviour should be setting image output size somewhere between 15000 and 19000px in width with constant proportion to height)
Image during rendering:
Image visible in image ditor after rendering finishes:
Here is closeup of the rendered and saved file:
Images have different resolution. Images inside image editor are displayed with rectangular pixels. Saved image have noise, image in image editor doesn't.
With such differences user is unable to validate scene, shader and render quality until the final image is saved to the disk:
Broken: 2.92.0 hash
6154aa1529
branch masterWorked: 2.90.1 hash
3e85bb34d0
hi-res_image_editor.blend
Added subscriber: @silex
Image Editor doesn't display correct image during rendering at very high resolutionto Image Editor don't display correct image during rendering at very high resolutionAdded subscriber: @filedescriptor
I cannot reproduce the issue.
During Render:
After:
They have the same resolution.
Thank you for checking. Please don't close it yet.
I assume you didn't change image output size from 19200x10800px?
If you can please save the rendered image and compare resolution of the image inside image editor in Blender with the resolution of the saved image. More feature-rich scene might be better example.
In my report resolution of the images inside image editor stays the same, but the pixels are shifted. The resolution difference is visible between image inside image editor and saved rendered image to the disk (opened with regular image viewer - just like in 4th picture in report).
I did not change the resolution and I have saved the render after. I don't see any difference in the pixels (Although it's hard to say without actually calculating the difference).
This is the saved render:
It's hard to tell from the image you attached, becase of the feature you chosed. In my 4th picture features on both images have the same size but different resolution.
Added subscribers: @Jeroen-Bakker, @fclem
Since 2.92 we use full sized buffer for displaying render result. But if the output is too big, we resize it so it can fit the GPU limitations (which is usually 16K these days).
We have the same issue if a texture is above this limit.
@Jeroen-Bakker will be working on a workaround for high resolution image display.
Fixed by https://developer.blender.org/rBbdd74e1e9338b18e4f80458f284d0c6a4d100f30
This report can be closed.
Thank you for your work @Jeroen-Bakker @fclem
Thanks for testing and reaching back to us!
