Blender thumbnail generation for Explorer is broken in 2.9x #84599
6 Participants
Reference: blender/blender#84599
Intel Core 2 Quad, 8 Gb RAM, NVidia GeForce GTX 1070 8GB
Windows 7 x64
Broken: 2.90, 2.91, 2.92
Worked: 2.83
It seems that thumbnail generation for Explorer for .blend files is broken because I cannot generate thumbnails for my .blend files when thumbnails are registered to Blender 2.9x. When I register my thumbnails to 2.83 or take the BlendThumb.dll file and replace it in my 2.9 folder, thumbnails starts to work again. I have tested this with 2.9, 2.91, 2.92 Alpha as well as 2.83 and I'm absolutely sure that there is nothing wrong with my registry because I have removed Blender 2.83 folder entirely and thumbnails still work but only when I replace BlendThumb.dll in 2.9x folder with the same file taken from 2.83, I've also did a thorough search through my registry to make sure that there is nothing pointing to the wrong place.
Added subscriber: @SpectreFirst
Added subscriber: @mano-wii
I tried with 2.92.0 Alpha, branch: master, commit date: 2021-01-03 01:04, hash:
1e8f266591
But I can't reproduce the problem.
It may be incompatible with the default version of Blender on your computer.
Which directory appears in DefaultIcon in the registry editor (regedit.exe) at
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\blendfile\DefaultIcon
?It may also be that you already have another copy of
BlendThumb.dll
in your system's search path andregsvr32
may be choosing that copy instead of the current directory.Run the command
Regsvr32 /u BlendThumb.dll
in the cmd and try again.I don't have any other folders except blender-2.91-windows64 and I'm always registering to the same blender-2.91-windows64 folder but it only seems to work with the file taken from 2.83. This is the first time I have this problem because prior to 2.9 I was I never had this problem.
Just in case, I will clarify how I test this:
EDIT:
I have also tried the same thing on another computer with almost identical system as mine which never had Blender before and found out a very peculiar thing - I've registered my Blender 2.83.10 or 2.9 and they have registered file associations but were unable to display thumbnails but when I've added 2.79b and registered it, my thumbnails began to display even after I re-register them to 2.91. I've tried to remove 2.79b folder and thumbnails stopped working again so I've searched my registry and found out that there are several Blender Thumbnail Handler still pointing to 2.79b, I've tried to manually change every entry to 2.91 and it didn't work. My primary computer doesn't even have 2.79b folder or any records of it in my registry but thumbnails still work with 2.83 and don't with 2.9. Frankly I don't understand what's going on but it looks like there is something in new Blender which doesn't get registered with blender -R command that used to register in 2.79b
EDIT2:
I have isolated the the problem between Blender 2.81a which does work and generate thumbnails and Blender 2.82a which do not. When I have both 2.81a and 2.82a folders, thumbnails work even when registered to 2.82 and stop when I remove 2.81, when I use only 2.81 they work.
Today I've got a new computer with Windows 10 on it and the problem was exactly the same - when I've registered to 2.91 or 2.92 it didn't work but registering to 2.79 and 2.81 worked immediately like it should so it seems that this is not exclusive to Windows 7.
Intel i9-10850k, 32 Gb Ram, NVidia GeForce GTX 1070 8GB, Windows 10
Added subscriber: @lichtwerk
Iirc, there have been changes again to thumbnail generation [cannot test this myself, I am on linux].
@SpectreFirst : just checking if this is still an issue with fresh builds from https://builder.blender.org/download/daily/?
Added subscriber: @LazyDodo
Also there's a button in the prefs panel to register the thumb+.blend association give that a try as well
{F10559907, width=100%}
I don't remember exactly when this landed, could be it's only available in the 3.0 daylies
I have tested the latest stable build 2.93.4 (downloaded archived Blender to a fresh new computer, unpacked, registered with Blender -R command) and thumbnails did showed up right away so it looks like something was indeed fixed in the latest builds.
And speaking of Operating System Settings - yes, it is presented in 3.0 alpha but not presented in 2.93.
Changed status from 'Needs User Info' to: 'Resolved'
Guess this can be closed then.
Added subscriber: @Leroy-Xie
This comment was removed by @Leroy-Xie
Added subscriber: @DAILUTEN
for blender 3.0 i opened CMD as admin an tap
chdir C:\Program Files\Blender Foundation*Blender 3.0* for me and enter
blender -r and enter again, it load and it was ok
