Specify per-object distribution ratio for moss use case #84608
Reference: blender/blender#84608
When instancing from a collection it is important to be able to specify at which ratio each object is instanced.
Existing workaround is to separate the points beforehand.
Prototype: P1906
{F9592504 size=full}
{F9603726 size=full}
Added subscriber: @dfelinto
Below are some notes on different possible solutions.
1. List all objects in the selected collection with their corresponding ratio in the node.
2. Use an integer attribute on points to determine which object are instanced on them.
3. Have multiple inputs and store a weight per input.
@JaquesLucke the 2nd and 3rd ideas are no different than using Point Separate with a couple of Point Instance node, correct?
They would just be a convenient way for users to do that in a single node
Well, that is kind of true for all three options. Convience and flexibility is what we are trying to achieve, right?
I think we should not mix external data (when the collection come from sockets) and local data (per-object count).
When not using "Use Count" it can work as it is now. With the collection that can come via a socket. However when users want to hand pick the use count within the node the collection socket disappears and the collection has to be set inside the node. This should cover the "common every-day use" use case.
Yes, I'm fine with that. It obviously has significantly less flexibility, but should be good enough for now. Also, if we ever decide to change that, writing versioning code to convert that to a more flexible approach should be possible (not so much the other way arount).
An early prototype just to prove the point: P1906
I will move this to a TODO task later, but have it filed for testing now (aka whether the design of the socket/socketless is clear).
{F9592507 size=full}
When switching "Use Count" it would be nice to sync the collection from the socket default value and vice-versa
Added subscriber: @zeauro
I like the third option of a weight and type per input.
That is more powerful and more intuitive.
No more global switch forcing to use 1 object or 1 collection.
We could mix simple objects outside or inside collection with a whole collection.
That is more powerful than what we have with less buttons.
Unfortunately, the mock-ups are not great.
We could have something really simple.
Per input settings like type or Whole Collection option could be set in Input panel of sidebar.
In sidebar, there could be a button to convert a collection input into corresponding objects inputs.
And instead of settings a count equal to zero for some objects of collection, user could simply delete inputs.
Edit : Oops. I just realized that I forgot weights.
There could be slider under each input.
Order of inputs could influence reccurence of objects.
I updated the mockup to be a bit more complete.
The proposed design can work and does solve the problem it set out to solve. Therefore I'm moving this task to done.
