Cell fracture not working on larger size #84622
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
2 Participants
Reference: blender/blender-addons#84622
Update cell fracture for larger size, please.
Blender>Add>Mesh>Plane>Edit Mode>Extrude to get a little bit of thickness. Scale to size 50 and then cell fracture will not work properly, at least for me.:-)
If I make cell fracture first in normal Blender size and then scale it to size 50 then my cell fracture with animation will not work properly in Unreal engine 4.
I'm working with Unreal engine 4 and the parts needs to be bigger for that.
Added subscriber: @wicster
Added subscriber: @rjg
Thank you for your report. Unfortunately, it does not contain the requested information, which are required for us to investigate the issue. Please read this guide , it may help you write a bug report that allows us to fix your problem.
Presumably the problem is that you need to apply the scale first using {key Ctrl A} > Scale.
In case you believe that you've found a bug, please create a new bug report through Help > Report a Bug in Blender. We expect all bug reports to follow the submission template . Please provide system information (operating system, GPU, graphics driver version), affected Blender version, previous Blender version that worked properly, a short and precise description of the issue, step by step instructions to reproduce it and, if relevant, a minimal .blend file that showcases the problem.
