Flashing vertices on screen updates #84627
7 Participants
Reference: blender/blender#84627
Windows 10 Home, version 1909, 64-bit
Broken: 2.83.0 - 2.83.10 (still broken as of latest 2.92.0 alpha experimental build
acbda123ad
)Worked: 2.82.7
Vertices flash when the screen is updating. Only on my desktop using a GTX 780, not my laptop using an i7-1065G7 (Intel Iris Plus)
Create an Ico Sphere with subdivisions set to 6. It happens at levels 5 and 7 as well, but not nearly as noticeable. It seems related to a specific vertex count, rather than proportional to the number of vertices.
Blender 2021-01-12 02-13-49.mp4
Added subscriber: @MontagueMGM
#94024 was marked as duplicate of this issue
Added subscriber: @filedescriptor
I cannot reproduce this. Could you provide the .blend file? What is weird to me is that in the video it seems that you have used a cube primitive.
This happens in the factory startup file. The object in the video was originally a cube (made into an ico sphere in edit mode), but the same thing happens with a new object created as an ico sphere directly.
Changed status from 'Needs User Info' to: 'Needs Developer To Reproduce'
Still can't reproduce (I tried latest master and latest LTS). Does the error come up as soon as you switch to edit mode? Do you select any vertices?
As soon as switching to edit mode, regardless of vertex selection
Blender 2021-01-12 04-18-41.mp4
Added subscriber: @rjg
Could you please save your full system information through Help > Save System Info and upload the file?
system-info.txt
Please open Blender's installation directory and double click on the
blender_debug_gpu.cmd
. This will start Blender in debug mode and create log files. Try to make Blender glitch again. Once it does, close Blender. The Windows Explorer should open and show you up to two files, a debug log and the system information. Add the debug log to your report.The glitch happens again but the debug output doesn't seem to show it: blender_debug_output.txt
Added subscriber: @danm3d
I also have a GTX 780 and am experiencing the exact same issue. Perhaps an issue with older hardware and newer driver (I'm running 460.89)?
Attached screen recording and debug logs below.
8YrVDuthce.mp4
blender_system_info.txt
Update: I clean installed the latest (461.40) drivers, however I get the same result.
Added subscriber: @Jeroen-Bakker
If this only happens with a GTX 780, I won't be able to reproduce this as I don't have access to that GPU. @Jeroen-Bakker Do you have one to test this?
Just found a task from last year detailing the same issue: #77731
Update: Upon further inspection, I noticed that the orange gradient on edges leading from selected vertices to nearby vertices isn't affected by this glitch. Maybe the difference in their rendering is key.
Added subscriber: @Code_Craft_Plugin
hi is this glitch fix cuz i having the same problem system-info.txt
Added subscribers: @mano-wii, @christian-clavet
