Undo doesn't work on UVmap deletion & only 5-6 UVmaps on same object possible #84690
2 Participants
Reference: blender/blender#84690
Operating system: Windows 10
Graphics card: AMD Vega64 (20.11.1 driver)
Broken: 2.92.0 Beta (Jan 14 build)
Worked: Testing older versions.
There are two seperate issues, both related to UVmaps (under Object Data Properties)
1. First of all the undo doesn't revert the deletion of UVmap (I tested with 2 recent versions of blender). even reverting the file doesn't work! (while blender is open).Exact steps for others to reproduce the errorHave multiple UVmapsDelete one using the '-' button on the right sideCtrl+Z to undo the deletion of UVmap (broken)Temporary WorkaroundsClose blender without saving, launch it againOr restore from a autosave5-6 out of 7 uvmaps are showing up correctly as intended, but only the lowest one in the list is displaying wrong (see attached image)
At first I thought I was doing something wrong, so I redid the steps a few times. But now I'm sure its a bug as:
Added subscriber: @SomeAB
I just tested this in 2.91.0:
Additional observations:
Added subscriber: @rjg
This might be a combination of multiple issues. Please wait for the next daily build that includes
01b9dfeab4
and test again.The undo part seems to be.
But the other issue is not (as it is broken in 2.91.0 as well).
I could not reproduce the second problem. I've created a minimal example project and it seems to work without any issues. Does this file work for you?
T84690_3.blend
@SomeAB Could you please provide a minimal example project that causes these issues in your project?
I will upload the file I was working on (its not a important project anyway). But will do tomorrow.
Here is the example file: https://drive.google.com/file/d/1U_h6f4njwUv6TtRfYJLSU8EY6G21yA3s/view?usp=sharing
The object 'Tree_Final' has the multiple UV maps.
How to reproduce:
Add another UVmap node + image texture node
In UV map node, select the 'UVMap_Tree_Original' .. and for image texture ..select "EonTexture_Tree_01".
Connect Each Texture node (now there shoudl be total 7 instead of 6) directly to the Material Output (Surface), one-by-one.
(IMPORTANT: Please notice that UVmaps currently in this file are projected from 6 sides: Top, Bottom, X1 (X-axis positive).. and so on. So X1 would look correct while viewing from X positive side only (numpad 3 to view it). This is NOT the issue.
However when viewing each of them from their respective sides, they should all look correct, but you will notice 1 out of the 7 (it happens randomly) .. won't look correct.
I was not able to reproduce the described issue. All image textures get correctly displayed from the respective perspective they've been projected from. Does the issue still occur for you with the current daily builds?
@SomeAB Are you still having this issue in current daily builds of Blender 2.92?
Thank you for the report. If the problem persists please open a new report with the required information.
