Debian Linux Blender can't see CUDA devices, says "CUEW initialization failed" #84802
Reference: blender/blender#84802
Operating system: Debian GNU/Linux 10 (buster)
Graphics card: Nvidia GeForce GTX 1070
Broken: 2.83.7, 2.90.1, 2.91.0
Worked: unsure
Blender is unable to use my Nvidia GPU for Cycles rendering. I have Nvidia drivers working, and I noticed that Eevee renders use the Nvidia GPU properly, as I can see 99% GPU utilization during Eevee renders using the
nvidia-smi
command.Under
Edit -> Preferences -> System -> CUDA
, an error message says "No compatible GPUs found for path tracing Cycles will render on the CPU".If I run blender with Cycles debugging on (
blender --debug-cycles
), I see an error related to opening a CUDA library:I0117 08:45:47.952724 1230 device_cuda.cpp:56] CUEW initialization failed: Error opening the library
blender --debug-cycles &
to start blender in the background with Cycles debugging onEdit -> Preferences -> System
and then chooseCUDA
underCycles Render Devices
error.Output of nvidia-smi command
Below is the output of
nvidia-smi
, which shows driver versions, etc. in case that helps. Just as an example of Eevee using the GPU successfully, this output ofnvidia-smi
shows 99% utilization during a computationally intensive Eevee render:Added subscriber: @brendenahyde
Added subscriber: @Alaska
What version of the Linux Kernel are you running? You can find out which version you're using with
uname -r
in the terminal/shell/etc.I ask this as with Kernel version 5.9 and higher, CUDA no longer works on Nvidia GPUs unless you are running driver version 455.45 or higher.
Another thing you need to do is ensure you have CUDA libraries installed. This can be done by running the command
sudo apt install libcuda1
Added subscriber: @rjg
As @Alaska said, please install the latest Nvidia driver for your GPU.
@Alaska @rjg thank you both. The issue was the Nvidia driver version as you said. Debian only has up to version 418 available in the normal repos, so I had to install the driver directly from Nvidia's website. This was a risk since it's not vetted by the Debian maintainers yet, but it worked, and my issue is resolved.
For the record, my kernel version is
4.19.0-13-amd64
.Just in case this helps someone else in the future, here is the Nvidia driver version I have now (upgraded from
418.152.00
):I appreciate your help!
Changed status from 'Needs User Info' to: 'Resolved'
Note for @brendenahyde . You can install more recent drivers officially verified by the Debian team using the instructions found here: https://backports.debian.org/Instructions/
I will write up my own instructions here:
sudo nano /etc/apt/sources.list
deb http://deb.debian.org/debian buster-backports main contrib non-free
and save the file withCtrl + X
sudo apt update
to update your sources list.sudo apt -t buster-backports install nvidia-driver libcuda1 libnvoptix1 nvidia-settings
to install the updated drivers and other useful libraries.There's a few things to note:
I have no idea how this will work with you installing the drivers straight from Nvidia's website.
In most cases this is NOT the most recent Nvidia driver, but it is usually within a month or so of the most recent.
Added subscriber: @woland.tel
Hope this should be helpful: https://devtalk.blender.org/t/nvidia-prime-is-here-but-cuda-not-found/15226/27?u=woland
