Blender Crash when creating PBR material via script #84866
9 Participants
Reference: blender/blender#84866
Graphics card: GeForce GTX 1080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 460.89
Broken: version: 2.91.0, branch: master, commit date: 2020-11-25 08:34, hash:
0f45cab862
Blender crashes when trying to add material created with a script. It seems to only happen with the advent of 2.91, but I'm not sure that's why. This happens especially with activated denoising.
blender_system_info.txt
blender_debug_output.txt
crash test.crash.txt
I have attached a project containing 4 textures and a script Made on purpose to simplify and test this error, that can be activated directly from the text editor, To simplify the reproduction of this crash.
Then Select the cube and press many time "Create 4k material" button.
Potential cause of the problem identified
I can say with certainty that this happens only if any template_list() interface is present regarding ob.material_slots.
Even the Blender UIList "MATERIAL_UL_matslots" if present in the user interface will crash Blender.
The crash will never occur if UIList is not present / visible
I can confirm with certainty that template_list() appears to be the cause of this crash.
When it happens, and when it doesn't:
Happens: Always when the preview icons are shown somewhere in the Blender panel in general.
Happens: Only when the Bump or Normal maps will be linked to the Principled BSDF node
It does not happen: Never when no node is connected to the "Normal" input of the Princlipled BSDF
It does not happen: Never in "ViewPorting Shading Rendered" mode with Cycles render engine
Happens: Always when "ViewPorting Shading Material Preview" mode with Cycles render engine
It does not happen: Never in "ViewPorting Solid" mode Never with Cycles or Eevee.
It does not happen: Never With Render Engine Eevee in (Solid/ Material Preview/ Rendered) Modes
Hardware configuration on another computer presents the same problem
I also tested this on an MSI laptop with intel i7 16GB Ram and Nvidia GTX960M but the same issue.
It seems random, but denoising seems to rage a lot, if activated it crashes almost immediately
I also noticed that it also seems to depend a lot on the size of the textures, I don't know if this is useful.
crash test.blend
Added subscriber: @Andrew_D-1
Added subscriber: @EAW
I cannot reproduce. I tried 2.91.0 and 2.93 alpha. This might be related to #84324, #81183, & #84438, which also involve NVIDIA Pascal GPUs and calls to
image_get_gpu_texture,
so it might be an issue only on that generation of hardware.Please try using the latest daily builds at https://builder.blender.org/download/ to see if that fixes the issue.
Unfortunately this also seems to happen on a RTX 3080 With properly updated drivers, and really, it's a completely random event (apparently). Unfortunately I have no way of reporting this stack at the moment, it was reported to me by a user, also on Windows 10 with Geforce RTX 3080/ AMD Ryzen 9/ 64GB RAM
I have received various reports from other users with this problem but only recently.
In any case, I also tried on yesterday's build of 2.92, and the same happens. I have updated the drivers several times, but this does not solve the problem.
In addition, if I can be of further help,to test the crash, I suggest pressing the "Create Material 4k" button several times repeatedly. Very often the crash occurs even without pressing repeatedly, but to do an immediate test, you need to press really fast, otherwise you risk not being able to reproduce the error immediately.
Added subscriber: @eklein
Added subscriber: @steffenthomas
I cannot reproduce. I tried 2.91.0 (E-Cycles RTX version). I tried on a RTX 2080 Ti.
Hello Thomas , thanks for your interest. Have you tried to rush a few dozen repeated clicks on the button? Sometimes I also struggle to reproduce this error. If I may suggest changing the Workspace, it seems that sometimes this also interferes. But I'm not sure about anything, I've done hundreds of tests. Sometimes it crashes immediately, I reopen the blender and it crashes again. Also 3 Times in a row yesterday. Then it magically works again for a few moments. This is accentuated on 4k textures, with 1K or 2K textures It doesn't seem to happen often.
Ok, i tried it again several times. Now i could reproduce the issue one time. I clicked about 60 times on the button as fast as i could and blender crashed.
Maybe i runs out of (video) memory?
It was not easy either to reproduce with rtx3090. If added really fast like 20 times and remove and did it a few times a got Blender to crash and exit consistently. I don't think is the memory since my GPU has 24gb and CPU 64gb.
Now for example, the crash occurs on my second attempt to add material.
This seems to happen when the icon preview of the material is rendered. This doesn't seem to happen in 'SOLID' mode
si3xCSNvGw.mp4
Added subscriber: @Pixelink
I Tested this on 2.91.
And it did crash after my 3rd click (fairly quickly)
RTX 2060 (4 GB)
16 GB RAM
Added subscriber: @rjg
I was unable to reproduce the crash so far. Does it still happen when in the daily builds of Blender 2.92 and 2.93 ?
Hello Robert, I've been testing right now both the latest 2.92 Beta Build, and the 2.93 Alpha as well. The same happens.
But I wanted to make sure, if you are also using a GTX 1080Ti (As I understand from your profile)
Anyway, if I can be of any help, This Crash also seems to depend on the viewing angle on the cube. Today I tried and I couldn't reproduce the crash, so I went through several Workspaces, then I moved the viewport (In random) and finally I was able to create the crash again. This without having to click repeatedly in bursts "Create Material 4k"
So if I can, I suggest you try the same, move the camera a bit, go through some workspace, for example Scripting-To-Layout, zoom in, rotate, zoom out the viewport, during these actions try to add the material.
I am aware that it looks like a fool, but I really don't know why, it seems to facilitate the crash.
Added subscriber: @mrusso81
@Andrew_D-1 I'm getting a lot of crashes using regularly Extreme PBR. I downloaded the .blend but could not find any script. Where is it located? Thanks
Added subscriber: @Punker3D
This comment was removed by @Punker3D
Using the provided blend file I get the crash after 2 clicks, repeatable.
macOS Mojave 10.14.6
Mac Pro (Mid 2012)
Processor 3.33 GHz 6-Core Intel Xeon
Memory 64 GB 1333 MHz DDR3
Hard Drive SSD
Graphics Radeon RX 580 8 GB
Monitor 34" Samsung 3440 x 1440
This comment was removed by @Andrew_D-1
Blender Crash when creating PBR material via scriptto Blender Crash when creating PBR material via script (Only when there is a UIList of materials in the interface)I have narrowed the field, updated the description (Take a look if you want), understood when exactly this happens, these exact conditions are needed:
Having Render engine Cycles in ViewPort Material Preview Mode, the preview icons Only if you show up somewhere will cause crash only if the Principled BSDF node has the Normal input connected.
So these conditions, only with these conditions the crash will happen.
I don't understand why not everyone crashes, but In any case Applying 10 times the material erases all 10 materials quickly, and reapplying 1 material 9/10 times on the fly causes crashes only under these conditions.
It still happens on version 2.92 from yesterday
Blender Crash when creating PBR material via script (Only when there is a UIList of materials in the interface)to Blender Crash when creating PBR material via scriptThere is no news about it but it seems the problem has remained 😅
Added subscriber: @lichtwerk
Since we really have troubles reproducing, me included, (and this report seems somewhat "stuck"), I would like to ask if (by any chance) the situation has improved in 3.0/3.1?
Could you check if this is still crashing for you in latest builds from https://builder.blender.org/download/daily/?
