ID User Decriment Error #84885
Reference: blender/blender#84885
Operating system: Mac OS
Graphics card: AMD Radeon Pro 5500M 8 GB
Broken: 2.80, 2.83, 2.91, and 2.92 from buildbot January 20th (
c2e6969c56
)Worked: 2.79
I've been getting this error consistently since 2.80 and it still shows up in 2.91:
Blender occasionally crashes after this. I'm assuming the crash is related.
I get the error when using an addon, and I've narrowed it down to the following cause:
bpy.types.Object
, and is a sub-property of a PropertyGroup registered to the scene as a CollectionProperty; not sure if any of that's relevant)ERROR (bke.lib_id):
...) when it is unlinked from the scene or deleted, or even if the PointerProperty from step 1 is referenced via code.I've tried for a few hours now to recreate this in a simple situation with a basic script but I can't do it. It comes up very consistently when using the addon, and given my research I know where the error is coming from, but I'm not sure exactly what to do to simplify it and give exact steps to reproduce.
Please let me know what further information I need to give if any. I'm hoping the issue cropping up here will be apparent with what information I've already given.
EDIT: I've been asked to include the addon as well as an example file. Attached below:
bricker_v2-3-0_demo.zip ID User Decriment Error.blend
Exact steps to reproduce:
Added subscriber: @bblanimation
Added subscriber: @lichtwerk
We also had e.g.
#71250 (ID user decrement error for Collections with ID properties in ViewLayer) or
#81345 (ID user decrement error when removing object which is referred to with a PointerProperty)
But to really proceedwith this issue, we'd have to have an example, reproducable script snippet where this happens.
Please continue to investigate if this can be reproduced in a simple scenario, as an alternative, you could also show this in the "real" Addon and share this here (with repro steps)
Will mark as "Needs Info from User" for now.
Added subscriber: @rjg
Could you provide us with a link to the add-on? It might be that it is improperly implemented and does something that is not permitted. For instance it may keep references to data while modifying the container. Common mistakes that can lead to crashes are explained in the Gotcha page of the API docs.
Added subscriber: @mont29
@lichtwerk please do not tag projects until report is fully validated. only adds noise in those projects then.
Sure thing – I've attached the addon as well as an example file above. I double checked the code where the error occurs and there are no lingering references to the data after it's removed, as far as I can tell.
Update: I also tried modifying the list created at line 284 of 'bricker/operators/delete_model.py' so that it simply stores the names of the objects rather than references to them. This didn't fix the issue - still got the same error.
First note: you are overriding existing operators:
Not 100% this is officially supported? Is this documented suggested somwhere?
Installing the Addon in a Debug build will already assert:
Simply tried renaming the operators (of course this will probably do something completely different then), Assert goes away, and the "ID user decrement error" also goes away.
WIth the original Addon, when removing
Bricker_Cube_parent
, it will haveLIB_FAKEUSER
, with my changes it wont.Will need to have another look with fresh eyes (above is not the root cause, it is just another issue with this particular Addon).
Of course it would help to isolate this as much as possible {same as in #81345}, but will check again next week.
@bblanimation: sorry, but given the fact that this might turn out to be a bag of mixed issues, I would like to ask for a simplified / more isolated example code snippet.
Afraid we have to close this now, please report this again if you can isolate this to a minimal script example as in #81345.
