Object selected outline not visible
Closed, DuplicatePublic
Operating system: Linux-5.4.0-62-generic-x86_64-with-debian-bullseye-sid 64 Bits
Graphics card: AMD VERDE (DRM 2.50.0, 5.4.0-62-generic, LLVM 11.0.0) X.Org 4.5 (Core Profile) Mesa 20.2.6
Broken: version: 2.92.0 Beta, branch: master, commit date: 2021-01-16 19:09, hash: rB6fb7d0f55927
Open Blender with General startup file. Click on the startup cube, but no yellow outline appears
/home/fido/BlenderLocal/GeneralStartup.blend
Robert Guetzkow (rjg) changed the task status from Needs Triage to Needs Information from User.EditedJan 21 2021, 2:26 PM
Please start Blender from the terminal with the following flags:
./blender --debug --debug-gpu > ~/blender_debug_output.txt 2>&1
Try to repeat the steps that resulted in the missing outline and upload the log file afterwards.
This issue could be related to T83488
Here is the log file for opening blender and not being able to see a yellow outline around a selected cube. Incidentally, the camera and light in the default blender do have a yellow outline.
  1. 16:00:42 fido@ultra:~$ cat blender_debug_output.txt
LLVM triggered Diagnostic Handler: Illegal instruction detected: VOP* instruction violates constant bus restriction
renamable $vgpr3 = LLVM triggered Diagnostic Handler: Illegal instruction detected: VOP* instruction violates constant bus restriction
renamable $vgpr4 = V_CNDMASK_B32_e32V_CNDMASK_B32_e32 32768,32768 ,killed $killed $vgpr3, implicit killed $vcc, implicit $exec
LLVM failed to compile shader
radeonsi: can't compile a main shader part
vgpr5, implicit killed $vcc, implicit $exec
renamable $vgpr3 = V_CNDMASK_B32_e32 32768, killed $vgpr3, implicit killed $vcc, implicit $exec
Switching to fully guarded memory allocator.
Blender 2.92.0 Beta
Build: 2021-01-17 00:01:06 Linux Release
argv[0] = sbin/blender
argv[1] = --debug
argv[2] = --debug-gpu
Read prefs: /home/fido/.config/blender/2.92/config/userpref.blend
read file
Version 280 sub 39 date unknown hash unknown
read file
Saved session recovery to '/tmp/quit.blend'
Blender quit
16:03:16 fido@ultra:~$
