Nodes Group input and output default value menu is undocumented. #84978
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
Reference: blender/blender-manual#84978
Operating system: Linux-4.19.0-13-amd64-x86_64-with-debian-10.7 64 Bits
Graphics card: GeForce GTX 1080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 418.152.00
Broken: version: 2.93.0 Alpha, branch: master, commit date: 2021-01-21 22:24, hash:
blender/blender@e391ad7bbc
Worked: ?
When in a group an input is a float that we convert latter to a vector, the result is different than when we use a value input...
Open the attached blend, it contains a cube with a material that showcase the bug.
When doing this it works as expected,
When using the value from the group's input it doesn't work
The .blend
Bug_Mapping.blend
Added subscriber: @sozap
Hum, by digging a bit I'm not sure if it's a bug...
In the group the default Value was set to 1, but in the value exposed "outside" the group it stayed at 0 probably because it was at 0 when the value was created.
Once I get out the group and set the value to 1 everything is working as expected.
It's a bit strange but I see why , I let the report here in case you want to address this as a papercut :
What looks logical to me is that unless you change the value "outside of the group" the value should keep the default that you set "inside the group".
Sorry for the noise !
Added subscriber: @EAW
I can’t seem to find a description as to what editing those values is supposed to do. So I would call this a lack of documentation issue. I’ll take a look at the code in the next few days to figure it out and add it to the manual.
https://docs.blender.org/manual/en/latest/interface/controls/nodes/groups.html
Shader Nodes Group input float converted to vector act weirdlyto Nodes Group input and output default value menu is undocumented. ted to actNodes Group input and output default value menu is undocumented. ted to actto Nodes Group input and output default value menu is undocumented.Added subscriber: @Blendify
Committed a fix as part of rBM7721
