Implement per-object distribution ratio for moss use case #85189
6 Participants
Reference: blender/blender#85189
{F9592504 size=full}
{F9603726 size=full}
Notes:
Initial UI prototype for socketless: P1906
Different workarounds:
Point Intance
nodes.--
Original design task: #84608
Added subscriber: @dfelinto
Added subscriber: @hadrien
It may be good to expose individual counts as sockets, so as to drive them from the modifier interface.
Is there a design reason why the collection socket would be hidden ? a technical one ?
Added subscriber: @KenzieMac130
I feel like instead of carrying the fixed burden of the old particle system. This might be a good use case for some sort of weighted random value selection node that can generate an attribute to be fed into the point instance node as an object index. This could also be controlled by ramps and noise this way.
I would ask around but I think it would be acceptable to users to select the object they want to instanced based on indexing its alphanumerical order (or maybe future string attributes) in the collection if they were given this kind of control.
Added subscriber: @Rawalanche
Yes, this seems like quite poor, hard coded design. Why should just the Point Instance node have this special hard coded thing? I mean everywhere around the entire GN systems, it will be desirable to have some per object variance.
Rather than having this kind of hard coded solution, why not establish some more generic system, which would for example utilize Custom Properties every Blender object can have, and then those could be used to drive parameters of various others nodes too.
So for example, I could create "Density" custom property on my object:
And GN could then access this property, and I could use this Density custom property float value as a multiplier of the "Count" value in the Point Instance node. And these custom properties could be used in other nodes too, to control other values.
Current design is so weird. For example what if I move an object out of collection and then back into it? Will the value get lost? Or will the node keep the value? If so, will it accumulating garbage of old values associated to no longer existing objects? Will these values be stored in the node?
Hi @hadrien:
If the collection comes from outside the node (e.g., the socket is connected to the Node Group as an input for the modifier) the node can't (shouldn't anyways) store data related to that.
Imagine a Point Instance node that is inside a NodeGroup that is used with different Collection inputs. Which objects to use for the object count?
For that reason the proposal has a clear separation when users want to specify the object count - thus all data is locally known to the node, so no sockets.
Added subscriber: @igiornotigi
I understand the perplexities in having "hard coded design" and lack of flexibility, but as proposed it would solve situations where otherwise we would need many more nodes and changes in more inputs that disadvantage the visual feedback.
I often find myself having to use the particle system instead of GM because of this lack.
It may be limited, but what it has to do it does well.
The design of the node has changed completely.
