Unable to use custom icon as bl_icon for Custom Node Tree #85213
2 Participants
Reference: blender/blender#85213
Operating system: Windows 10
Graphics card: Nvidia RTX 2080 ti
Broken: 2.83.10
Worked: Not sure if ever worked
When setting the icon for a custom node tree you can only set it to the blender icons. It seems like the node tree is loaded or checked before it is registered as the variable
custom_icons
always is called before it can be assigned as an image preview.Exact steps for others to reproduce the error
Based on the attached .blend file just try to install and enable the addon. Depending on what is commented out the error will either say
'NoneType' object is not subscriptable
ifcustom_icons
is set toNone
initiallyor
KeyError: 'logo'
ifcustom_icons
is set tobpy.utils.previews.new()
initiallyIconTest.zip
Added subscriber: @Zeastin
Added subscriber: @rjg
For
bl_icon
you have to assign a valid enum as listed in the Python API docs .If you assign
None
to a variable and then try to access it like and array that results in this errorIf there is no entry with the key
logo
then this is the error you will see. Initially the collection doesn't contain any entry.If you need help learning or using Blender, please post a question on one of our [community websites ]], for instance https:*blender.stackexchange.com/ , https:*blenderartists.org/ or the [ https:*blender.chat/channel/support | #support channel on Blender chat . The bug tracker is only for bug reports.
@rjg Thank you for your response!
Apologies, but this would seem like unexpected behavior since almost everywhere else you can add an icon you can also add a custom icon even if it is an icon_value.
And the reason I added it as a bug was due to the seeming brain dead obvious errors in that no matter what I initially assigned to
custom_icons
it is never given anything before the Node Tree tries to access it. In the addon I included in my message you might have noticed thatcustom_icon
should be filled before it is referenced by bl_icon. I was not seeking help in learning. Thank you for your time@Zeastin the errors you are getting are entirely unrelated to whether
bl_icon
allows to assign a custom icon. Even if it would be supported the script wouldn't work. In both variations the variable doesn't contain the data you're expecting at the time it is accessed, hence the error message that one time it isNone
and thus you can't access it with an index, and the other time because the collection doesn't contain an entry with the keylogo
. If it is unclear to you why that is the case, then please create a question on Blender's Stack Exchange , post a link to it here and I will try to answer it.
